Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
convergence in 2 phase flow
Like Tree1Likes
  • 1 Post By luccy
Old   September 13, 2015, 11:11
Default convergence in 2 phase flow
luccy is on a distinguished road
hi
someone can tell me that this run has converged or not? convergence criteria is 10^-6,why continuity is Fluctuating .is this mean that it is not converged?
i used mixture model,and piso,and skewness correction and neighbor correction=1 and
under relaxation factor is: pressure=.2, mom=.2,k=.5,e=.5 and mesh is triangular and 2d
can i reduce relaxation factor in piso from default value or not?
tanx
Hesam_Ami likes this.
luccy is offline   Reply With Quote
Old   September 23, 2015, 03:17
hwet is on a distinguished road
Doesnt seem converged to me
hwet is offline   Reply With Quote
Old   September 23, 2015, 06:40
please tell your reasons.
tanx
Old   September 23, 2015, 10:19
actually i just noticed that continuity has reached less than 10e-6 residual as well. what criteria have you set? usually at continuity residuals of 10-4, the iteration process should stop by itself
Old   September 24, 2015, 05:11
Cees Haringa
CeesH is on a distinguished road
Your continuity residual might be fluctuating - but remember that it's very small already. So what does this little bit of oscillation matter? Lowering underrelaxation factors may 'solve' it, but in the end, your Cd and mass flow look like they are already constant up to 4-5 digits, so will any more accuracy really be significant? I think this convergence looks fine. I wouldn't draw too many conclusions on the residuals anyways, having constant averages/coefficients is a better judgement, IMO.
CeesH is offline   Reply With Quote
Old   September 24, 2015, 13:56
tanx for response.
what's your idea about hwet's response??should iteration process stop by itself in convergence?(my simulation is unsteady)
Old   September 24, 2015, 15:22
Cees Haringa
It depends on what criteria you set. But never ever ever base these criteria solely on residuals, as they are very system dependent. I ran simulations where the solution was constant up to 0.01% in all relevant parameters, where the residuals were ~ 10^-3. I've also had simulations where the residuals were < 10^-5, and the relevant parameters oscillating by more than 1%.
You can also set convergence criteria in FLUENT that are based on average numbers or so - for example, the solution is deemed converged if the solution is stable within a certain predetermined range, for X iterations. These are more suitable criteria to judge by. If you set goals for the residuals only, make sure to check whether your relevant parameters actually reached a constant value before analysis. You can always opt to run some more iterations with stricter settings.
Old   September 24, 2015, 15:54
tanx very much
Convergence Centurion2011 FLUENT 48 June 15, 2022 00:29
Two phase flow solid-fluid in river beds Samchak Main CFD Forum 0 May 23, 2013 09:44
gas-liquid 2 phase flow in microchannels using VoF LyngHoo FLUENT 1 November 13, 2012 20:01
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 18:57
Convergence for inviscid flow over sylinder Rjakk Main CFD Forum 2 March 21, 2007 11:53
