Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
simulation PHP(pulsating heat pipe) with mixture model
Like Tree1Likes
  • 1 Post By quaker90
Old   July 15, 2015, 02:08
Default simulation PHP(pulsating heat pipe) with mixture model
ByeongChan Kim
quaker90 is on a distinguished road
Hi, I'm trying to simulate PHP in FLUENT.
With copper tube(3mm), water charged 50% volume fraction.
There's constant heat flux(5W/m^2) at bottom side and constant temperature(298.15K) at the opposite side. (adiabatic for middle)
I used mixture model, and other settings below
Phase - Phase interaction - Mass - evaporation-condensation
Phase - Phase interaction - Surface Tension - 0.045 n/m
Solution Initialization - Patch - fluid - 0.5 volume fraction for vapor.
my question is
1. Do i need to use UDF for mass transfer? because i used phase change for
evaporation-condensation mechanism
2. The result is no successful. there's no vapor plug and liquid slug with pulsating motion. I want to know what is missing in my system
artawina likes this.
quaker90 is offline   Reply With Quote
Old   July 21, 2015, 02:24
Ram Kumar Pal
rampal is on a distinguished road
hi.. my project topic is also simulation of "pulsating heat pipe" in fluent, i'm not so good in fluent, i'm learning to solve two phase problem including vof model and reynolds stress model. please provide suggestions regarding my project topic.
rampal is offline   Reply With Quote
fluent 14.0, heat pipe, mixture model, two phases
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
How to Model Heat Pipe Heat Pipe FLUENT 12 January 24, 2020 03:27
heat pipe simulation in Fluent nahmed FLUENT 15 December 15, 2015 05:11
An error has occurred in cfx5solve: volo87 CFX 5 June 14, 2013 18:44
simulation of heat pipe (evaporation part) DanielLai FLUENT 0 November 5, 2011 11:26
