how to define more than one species in one phase? |
June 15, 2015, 05:59 |
Linwei
Rep Power: 11 |
For this chemical reaction: C(s) + O2(g) = CO2(g). I want to set O2 and CO2 as different species in gas phase. But only one kind of material can be chosen when setting primary phase under "Phases". How can I do? Thank you very much.
June 15, 2015, 06:31 |
Cees Haringa
you need to also enable the species model, and tick the option 'volumetric reaction' there to be able to set up reaction equations.
June 15, 2015, 15:38 |
#3 | |
Linwei
Rep Power: 11 |
Thank you! I have known how to define more than one species in one phase. But another question is how can I set the volume fraction for each species? Thank you very much. |
June 16, 2015, 08:38 |
Cees Haringa
Like you would do with single phase. Under boundary conditions, you have the tab 'multiphase' for inlets to set the volume fraction of phase 2.
In each separate phase, you have the species tab to set the mole or mass fraction of each species in that particular phase. Best, Cees |
June 16, 2015, 09:19 |
#5 | |
Linwei
Rep Power: 11 |
Thank you very much. I Know I can set the volume fraction of Phase 2 under boundary conditions. I wonder how to set the mole or mass fraction of each species in the gas phase after I defined the material under Species--Mixture Material. Thank you. |
June 16, 2015, 10:34 |
Cees Haringa
As mentioned, you can also find 'species' under boundary conditions.
You can find this both when considering the conditions for phase 1 and for phase 2, where for each phase, you can set the adequate mass or mole fractions for the species. |
June 17, 2015, 07:57 |
#7 | |
Linwei
Rep Power: 11 |
Yes, I have found that! Thank you very much!!! |
May 30, 2016, 07:16 |
#8 | |
Wang Jie
Rep Power: 10 |
I used the Eluer model , I defined the primary phase is water-liquid and the second phase is the mixture of water-vapor and air . But I am failure. the soft donet that there must be more than one species on each phase! could you tell me what should I do ? Thanks a lot ! |
May 31, 2016, 07:14 |
#9 | |
Linwei
Rep Power: 11 |
May 31, 2016, 11:14 |
#10 |
Wang Jie
Rep Power: 10 |
Thanks you very much!
Mybe I didn't describe my question. I mean I enable model "Species" and Eluer model at the same time. Defined the primary phase is water-liquid and the second phase is the mixture of water-vapor and air. When I clicked initialization, the soft reminder that there must be more than one species on each phase! What reason is this? Thanks. |
May 31, 2016, 21:45 |
#11 |
Wang Jie
Rep Power: 10 |
January 15, 2018, 05:47 |
error i am getting in Fluent " there must be more than 1 species on each phase"?
#12 |
Lister
Rep Power: 11 |
I am using multi-phase Eulerian granular model. I have activated the species model. I am trying to find layering on a solid surface from the bulk solution. I am having 2 phases ( 1 liquid phase + 1 solid phase)
April 28, 2020, 12:12 |
#13 |
alonge sanmi
Rep Power: 11 |
Hello. Pls were you able to find the solution to specifying more than one species for a phase?. I am also receiving the same message as I try to initialize my problem.
September 22, 2020, 06:12 |
simulating evaporation of water in presence of non condensable gas (air).
#14 | |
Tapan Dave
Can you please tell how to define 'more than one species' in water_liquid! I am trying to simulate water vapour evaporation in presence of non condensable gas (air). I have switched on 'VOF_eularian model/VOF_mixture model', species transport equation, energy equation. Phase1 is defined as 'water vapour+ air' and Phase2 is 'water(liquid)'. In 'Phase iterations'>'mass' tab>'species mass transfer' mechanism is used/activated. With In species mass transfer model:-'two resistance model'>'zero resistance' is activated. I am getting error : 'There must be more than one species on each phas' |
September 22, 2020, 06:13 |
#15 | |
Tapan Dave
Did you find the solution of the error?? Can you please tell how to define 'more than one species' in water_liquid! I am trying to simulate water vapour evaporation in presence of non condensable gas (air). I have switched on 'VOF_eularian model/VOF_mixture model', species transport equation, energy equation. Phase1 is defined as 'water vapour+ air' and Phase2 is 'water(liquid)'. In 'Phase iterations'>'mass' tab>'species mass transfer' mechanism is used/activated. With In species mass transfer model:-'two resistance model'>'zero resistance' is activated. I am getting error : 'There must be more than one species on each phas' |
September 16, 2022, 01:55 |
Alternative way to define more species
#16 |
Yunsung Park
I also met the same messeage, and figured out to avoid it.
Copy one of mixture phase, and define them as liquid phase. In liquid phase, define two liquid species. One is your species, the other is some random one And I just simply set the concentration, inflow, everything as 0 for the random species. Hope this trick will work to your problem |
species phases |
Help me to check my UDF | Liufeng_ustb | Fluent UDF and Scheme Programming | 2 | May 7, 2013 11:25 |
how to define multi phase condition | MMF | FLUENT | 0 | May 9, 2010 09:31 |
species transport and discrete phase modeling .... | farhath | FLUENT | 2 | February 11, 2006 02:09 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 2, 2003 00:32 |
Problem on boundry of two phase flow | youngan | CFX | 0 | June 30, 2003 03:32 |
