March 30, 2015, 11:41 |
Eulerian Multi-Fluid Vof model?
Rep Power: 16 |
I need to know what types of two phase flow patterns can be solved with the Eulerian Multi-Fluid Vof model? please give me answer?
April 4, 2015, 01:23 |
Rep Power: 14 |
To my knowledge, the most simulated flow pattern by vof model is bubbly flow in tubes
April 4, 2015, 08:24 |
Rep Power: 16 |
Hi thanks for the respond. What about stratified two phase (Air-water) flow in a tube? can be modeled with Eulerian Mulit-Fluid VOF model?
April 9, 2015, 05:37 |
Rep Power: 13 |
Download the Fluent theory guide, it tells you with pretty pictures of applications of each of the different multiphase models available.
July 24, 2017, 04:14 |
#5 | |
Masoud Ravan
Rep Power: 10 |
but the theory guide didn't explain the theory of this model... Did you find any data or example of this model? |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Mixture model + VOF? | blacksoil2012 | Fluent Multiphase | 2 | February 9, 2014 00:59 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
question about Heat transfer between two phases with VOF model | sooroo3 | FLUENT | 0 | February 15, 2011 04:24 |
air bubble is disappear increasing time using vof | xujjun | CFX | 9 | June 9, 2009 08:59 |
