Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
How do I set up initial particles condition?
Like Tree2Likes
  • 1 Post By `e`
  • 1 Post By `e`
Old   March 16, 2015, 04:36
Default How do I set up initial particles condition?
sohn donh kyung
sohn is on a distinguished road
Hello.
I wanna simulate a fluidized bed reactor with initial particle condition by using fluent DPM.
but, I am so confused about making initial information file for particles.
I made file like below and set up by injection
---------file start---------------------------------------------------------------
((x y z u v w temperature diameter mass-flow)name)
((-0.0060 -0.0735 0.0015 0.0 0.0 0.0 300.0 0.0025 0.0) injection-0:0)
((-0.0030 -0.0735 0.0015 0.0 0.0 0.0 300.0 0.0025 0.0) injection-0:1)
---------file end----------------------------------------------------------------
but, I only can see below massage
ERROR reading particle 0 for injection: injection-0.
Particle streams from injection-0:
STREAM ...........................INITIAL VALUES...........................
NO TYP (X) (Y) (Z) (U) (V) (W) (T) (DIAM) (MFLOW)
I don't know what is the problem. T T
Please anybody help me.
thank you for your help!!
sohn
sohn is offline   Reply With Quote
Old   March 16, 2015, 05:55
`e`
`e` is on a distinguished road
Is the line "((x y z u v w temperature diameter mass-flow)name)" literally in the injection file? Remove this line.
sohn likes this.
`e` is offline   Reply With Quote
Old   March 16, 2015, 09:31
sohn donh kyung
Thank you, e.
The error massage disappears due to your recommendation.
But, I have a new problem.
I can't find my initial particle in my domain through the calculation!!
I want that my particles just stay at given position.
What can I do for that?
Regards
sohn
Old   March 16, 2015, 17:06
`e`
If you wanted your particles to remain stationary (why?) you could set the drag, gravity and other particle forces to zero. Then your particle would have zero acceleration and remain still.
sohn likes this.
Old   March 17, 2015, 01:12
sohn donh kyung
Thank you for kind answer, e
I mean..
I can't see any particles in my domain.
It seems that the initial particles don't evolve in my computation.
I still see below massage while the 'ERROR' word disappear.
Maybe is this the problem?
Regards
sohn
Old   March 17, 2015, 05:17
`e`
Try setting a mass flow rate for the injection streams.
Old   June 29, 2015, 09:17
Eric Bachmann
Eric_TUI is on a distinguished road
I am new to Fluent and I am also doing DPM and DEM.
I think the order in your injection file is not right. My files are in this order:
((x y z u v w diameter temperature mass-flow)name)
And I´m not using a header in my files. Also you have to set a massflow. Use a very small stoptime (smaller than your timesteps) in your injection an than you have to set your massflow like this:
mf = mass of one particle / stoptime
Hopefully this works for you.
Regards
Eric_TUI is offline   Reply With Quote
dpm, fluent, injection, particle
log file imani OpenFOAM Running, Solving & CFD 0 July 24, 2014 03:04
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
Error while running rhoPisoFoam.. nileshjrane OpenFOAM Running, Solving & CFD 8 August 26, 2010 13:50
