Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
effect of porosity in the porous media
Like Tree1Likes
  • 1 Post By Rui_27
Old   October 13, 2014, 11:02
Default effect of porosity in the porous media
Rui_27 is on a distinguished road
Hello to all,
I am modeling two-phase flow (water and air) through a channel that as a porous and a non-porous region.
I am confused about the effects of the porosity of the porous media in the simulation. By reading Fluent's manual I understand that, as I was expecting, porosity is the void space of the porous region, i.e., the space where the fluid(s) can flow.
However, when i changed the porosity, the results are not as i expected. In the figure attached*, you can observed that increasing the porosity makes water to flow "slower" in the porous media, and i was expecting the opposite!
* Air is entering at the upper part of the channel (from left to right) while water is entering at the bottom part of the channel (the porous media) and through a porous directly into the upper part of the channel
I also found in Fluent's manual that porosity affects heat transfer properties (which is not considered here) and the time-derivative in the continuity equation. However, I don't understand how can this lead to the results i obtained.
Can someone help me? Thanks!
Rui_27 is offline   Reply With Quote
Old   October 22, 2014, 14:03
The answer to this question:
"With a low porosity the physical velocity is higher and therefore the water would seem to flow faster. Essentially at low porosity there is less open volume and therefore for a given inlet volumetric flow the time to fill will reduce. At a porosity of 1 the volume is at its maximum and therefore the time to fill is longest."
Thanks to David Stanbridge (swiftaircraft)
ghost82 likes this.
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 8 May 30, 2024 03:59
Porous media setup issues in Fluent Bernard Van FLUENT 29 January 26, 2017 05:09
How to model granular flow through porous media Axius FLUENT 2 August 7, 2014 11:34
porous media with variable porosity Kevin A. FLUENT 3 December 24, 2006 11:56
porous media: Fluent or Star-CD? Igor Main CFD Forum 0 December 5, 2002 16:16
