August 12, 2014, 04:09 |
Volume fraction problems
Rep Power: 13 |
I'm a beginner with CFD, Fluent, Multiphase & VOF. So please bear with me if my question is too obvious.
I am modeling a distributor, with 1 inlet & 4 outlets, trying to find the volume fraction of my 2nd phase & have been following the instructions I found here & in the manual. But somehow I ended up with this (attached pic): 2 distributors instead of one!!!! & the gradient of results is stuck in 3.5e-1 for all colors!! I don't know what I did wrong Please help me |
August 13, 2014, 09:52 |
Rep Power: 13 |
I'm simulating the 2phase flow inside an air conditioning distributor, using water as the working fluid in 2phases (liquid & vapor)
I want to show the contours of the volume fraction of phase 2, but I have a problem where it appears as constant throughout the whole domain (with the gradient on the left stuck on the same value, my original value of 0.35), the same thing happens with the 1st phase but with the value of 0.65. I read on the topic & I found about patching, although all the tutorials, examples & forum posts suggest using 1 or 0 for the initial value of the 2nd phase, and it's always a simulation of water & air. So I am not sure if it applies to my case. However, my domain has water in both phases simultaneously, from the very first point of the domain. I don't know if the problem is my solution method : Coupled & PESTO or that I'm not doing the patching properly, or there's something wrong with my time steps? Or should I use a UDF? I don't know how to program those, "yet", but if u think that's the solution to my problem, then I may give it a try. Please help me out. Any input will be helpful. |
August 20, 2014, 04:35 |
Rep Power: 14 |
Hello rgd,
the volume fraction shown in you picture is right after initialising the case without any calculation (time = 0). Regarding this time it is perfectly normal to look like this due to Fluents settings. Regarding the two domains, did you set any view settings? (mirror etc.) It should be possible to patch any other values than 0 or 1 for the phases (I am not sure on this one i never used it) The vF value is a percent of the phases (35% Phase 2 and 65% Phase 1 in your case) You are using the Euler-Multiphase model right? If I am correct are your particles smaller than your cells? (This is a must for the Eulerian modell). Is there any problem if you start with 0% of your Phase 2 insinde the domain? As a boundary condition set the vF for you Phase 2 at the inlet to 0.35 and see what happens. Greets Nigirim |
August 22, 2014, 07:37 |
#4 | ||||
Rep Power: 13 |
Dear Nigirim,
Thanks a lot for ur reply. I really appreciate it. Quote:
I started using smaller time steps in the order of 1e-5 to 1e-7. I started getting nicer profiles for the volume fractions at different time steps by: Read>Data>time step, usually until 120-140 I get good profiles with a good color map showing the change in the volume fraction. After that it goes back to a similar profile, with the whole color map stuck at 0.35. The thing is I am trying to find the mass flow rate at the outlets, so it means it should reach equilibrium, when Qin=Qout, right? so that the sum of mass flow rate at inlet + mass flow rate at outlet = zero (approximately), this only happens when the color map is stuck on 0.35. I also want to find the volume fractions at the outlets, at the same time, in order to show the maldistribution at the different outlets. But when I try to find the volume fractions at the equilibrium state it shows as the picture. I don't know what to do to find both, to be the final values, not the time step values. Quote:
But if u think I should use Eulerian model, could u please explain to me why? I really appreciate ur input. And thanks a lot for all ur help. Regards, Raghda |
September 4, 2014, 06:44 |
heat pipe
Muhammed Asmail
Rep Power: 17 |
Hi all
Please i need the boundary condition of volume fraction in heat pipe by using ANSYS-FLUENT program |
September 4, 2014, 15:36 |
Rep Power: 13 |
Hi Muhammed,
u want to know how to set it, right? u can go to boundary conditions> highlight ur inlet from the zone menu & choose ur secondary phase from the phase drop down list> then press edit > & choose the multiphase tab: there u can set ur volume fraction of ur secondary phase. Hope this helps. |
September 4, 2014, 16:54 |
heat pipe
#7 | |
Muhammed Asmail
Rep Power: 17 |
i want to know the boundary condition for volume fraction of thermosyphon heat pipe that it is enclosed with this message,as the same the path that you wrote it to me? and how much value of the volume fraction for this case? Many Thanks |
June 22, 2017, 11:02 |
#8 | |
Yaqub Yaqub
Rep Power: 9 |
Sent from my LG-D851 using CFD Online Forum mobile app |
June 22, 2017, 11:07 |
#9 |
Yaqub Yaqub
Rep Power: 9 |
A question pls, my case is a porous media with initial saturation of two fluids and one of the fluid pumped inside from inlet to displace the original fluid. I tried to set inlet as velocity with prim phase as 0velicity and sec phase given velocity with volume fraction 1 while I used the patching for the initial saturation, ie prim phase 0.8 and sec phase 0.2 but my results are wrong. Please any contributions?
Thanks Sent from my LG-D851 using CFD Online Forum mobile app |
July 4, 2017, 02:39 |
#10 | |
Sent from my SM-G900I using CFD Online Forum mobile app |
March 1, 2018, 13:19 |
Void fraction calculation
#11 | |
Raj
Dear Raghda
Were you able to resolve your problem? I am stuck with the similar problem. Please suggest. Quote:
Raj |
January 28, 2020, 11:39 |
#12 |
Ali
Hi
I'm simulating an expansion valve in fluent and I have this problem with volume fraction when it's set to 1, the numbers in phase 2 counter are constant and whenever I set it to below 1 numbers seems to be okay but the energy equivalent won't be calculated. Could you please tell me what I'm doing wrong? Simple method, mixture multiphase |
January 28, 2020, 11:43 |
Expansion valve
#13 |
Ali
Hi
January 30, 2020, 04:50 |
Description unclear
#14 |
Hi Ali
The description you share is not very clear. What is meant by energy equivalent and numbers in phase 2 counter?
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
2 phase flow, vof model, volume fraction, volume fraction gradient, volume fraction. |
Volume fraction of dispersed phase to determine DPM, VOF, Mixture model | Mohsin | FLUENT | 5 | March 5, 2018 08:47 |
volume fraction = nan | Virtual-iCFD | OpenFOAM Running, Solving & CFD | 8 | June 12, 2015 19:15 |
Weighted average volume fraction | Yasser | FLUENT | 5 | April 11, 2015 09:25 |
InterFoam channel Flow runnig very slowly | Wokl | OpenFOAM Running, Solving & CFD | 4 | January 9, 2014 03:52 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 14:06 |
