Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Confluence of two flows with different density
Like Tree1Likes
  • 1 Post By CeesH
Old   August 6, 2014, 08:31
Default Confluence of two flows with different density
Pedro Ramos
pedroxramos is on a distinguished road
Hello there!
I want to simulate the confluence of two flows of fluids with different density in an open channel, like this:
How I define the different inlets zones with two different fluids?
pedroxramos is offline   Reply With Quote
Old   August 6, 2014, 08:57
Cees Haringa
CeesH is on a distinguished road
Hi Pedro,
In your mesh, define 2 velocity inlets (at least, I assume you have a (constant) velocity profile for both fluids that you know?)
In boundary conditions, you can set the velocity inlet specifications.
Under phase-2 specifications, you can set the velocity and volume fraction of your second phase. Setting that to 1 means the inlet is pure phase-2, setting it to 0 means pure phase-1.
Best,
Cees
pedroxramos likes this.
CeesH is offline   Reply With Quote
Old   August 6, 2014, 10:13
Pedro Ramos
Thanks for your reply.
But the problem is that for each inlet I have one different fluid and air. So, in the inlet 1 enters water + air and in the inlet 2 enters mud + air.
What should I do? I know that I should use VoF, right?
Old   August 6, 2014, 10:36
Cees Haringa
Hi Pedro,
Could you tell a bit more about the setup? What you are describing now would actually be a 3 phase flow... do the water and mud mix? how is the flow distributed (are air & water separated in the inlet, or do you have a bubbly flow) and what's the size of the domain?
VOF is only useful in case there is a sharp boundary between the fluids which you can explicitly resolve; for a bubbly flow of macroscopic dimensions it is pretty much impossible to apply and you need to look into eulerian multiphase. But if the gas and water flow completely separate of eachoter, VOF may be an option...
Old   March 16, 2015, 02:59
Ramakant Gadhewal
Location: Chemical Engineering,National Institute of Technology,Warangal (T.S.),India
ramakant is on a distinguished road
Originally Posted by pedroxramos View Post
Hello there!
Dear Sir
i am modeling lake\river flow with two different types of fluid is flow into the river but the properties of the fluid is different i.e.density,viscosity and the other properties . i need you help regarding the multiphase model which model is used such types of problems
ramakant is offline   Reply With Quote
difference between density and density all preetam69 FLUENT 1 November 1, 2014 21:49
Gravity/Buoyancy/Buoyancy reference density in two phase flow sharifi CFX 10 June 9, 2014 11:23
Density XY plot of a plane flow_CH FLUENT 0 July 25, 2013 11:01
SIMPLE pressure correction in compressible flows Maarten de Jong Main CFD Forum 7 April 30, 2012 03:23
Warning 097- AB Siemens 6 November 15, 2004 05:41
