Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
modelling evaporation-condensation in closed system
Like Tree1Likes
  • 1 Post By alimondegari
Old   October 12, 2013, 12:07
Default modelling evaporation-condensation in closed system
ali mondegari
alimondegari is on a distinguished road
hi
i am modelling a two-phase flow for water liquid and vapor in steady state in a closed system . it contains evaporation and condensation. is using VOF right for this case ? i fill half of the system with water in initialization but after some iteration total mass of system decrease significantly and continuity equation never converge . what's the reason ?
please help me
thanks
aamev likes this.
alimondegari is offline   Reply With Quote
Old   February 6, 2014, 09:17
amine
aminem is on a distinguished road
I try to simulate the same problem. I use a mixture model with tree phase (air, liquid, vapor). After few iterations I have this message: # Divergence detected in AMG solver. I had try to change the under relaxation value, but is diverge as well.
aminem is offline   Reply With Quote
Old   February 20, 2014, 13:08
amine
Hi
You must use a transient solver for a good convergence.
I used a coupled scheme with flow number of 50I used 0.001 s time step to have stable convergence
Good luck
Old   April 25, 2014, 01:09
Xiaobing Zhang
xiaobingwill is on a distinguished road
Hi guys,
I'm doing similar problems right now. So did you use Fluent evaporation-condensation model to do the calculation or wrote your own udf for the simulation?
xiaobingwill is offline   Reply With Quote
Old   April 25, 2014, 01:20
Xiaobing Zhang
Hi guys,
In my view, if you use VOF to do this simulation, you should write UDF by yourself for the eva-conden process. But if you turn to Mixture model, you can use the written model.
evaporation and condensation aximefu CFX 4 May 14, 2012 00:09
Water Evaporation and condensation modeling Linjie FLUENT 3 February 6, 2012 14:08
Boussinesq approximation in closed system Nitesh Main CFD Forum 4 July 10, 2006 10:23
Combustion in a closed system. Jim Main CFD Forum 7 December 9, 2004 14:49
closed system calculation Neil MacLeod Main CFD Forum 1 May 13, 1999 16:47
