Home > Forums > Software User Forums > ANSYS > FLUENT > Fluent Multiphase
Difficult to model using vof
Like Tree1Likes
  • 1 Post By jamalf64
Old   July 5, 2013, 15:41
Default Difficult to model using vof
elahe65
elahe65 is on a distinguished road
I will be very grateful if you could answer my question, I want to a two-phase model using vof, including water and air. Do I need to define the two-volume in gambit or in Fluent need to do this?
For example, 0.15 m air and 0.2 m water in the canals, where should I enter these values? how about the volume fraction According to these values?
elahe65 is offline   Reply With Quote
Old   July 5, 2013, 19:49
Jamal Foroozesh
jamalf64 is on a distinguished road
You dont need to define two volumes in gambit.
after initialization in fluent you must patch second phase.
step by step: 1- define air as primary phase 2- define water as secondary phase 3- initialize 4- adapt/region/define range of x,y,z for patch secondary phase/mark 5- solve/initialize/patch(phase:water/variable:volume fraction/register to patch:marked zone in step 4/ click patch) 6- iterate
I hope this help you
Jamal
6863523 likes this.
jamalf64 is offline   Reply With Quote
Old   July 6, 2013, 01:49
FHydro
flow_CH is on a distinguished road
I am doing this subject but when i am using open channel flow boundary and patch the water, after a few iterate, the water height is good but after more iteration water is going up and Occupies whole the model.
I think the problem is due to initialize option. Every time i choose compute from all zones, this problem occurs and Every time i enter x velocity, just a little water enter from inlet and flowing to downstream( there is no flow, back of that water)
please help
flow_CH is offline   Reply With Quote
Old   July 6, 2013, 04:38
Jamal Foroozesh
I think the problem is due to initialize option. Every time i choose compute from all zones, this problem occurs and Every time i enter x velocity, just a little water enter from inlet and flowing to downstream( there is no flow, back of that water) see attached image
please help
you must wait until solution be converged. this way(your method) is wrong to judge.
Old   July 6, 2013, 06:30
FHydro
which case? the first that water Occupies whole the model or about two images?
Old   March 14, 2014, 12:36
thermal energy is on a distinguished road
Hello dear friends,
I try to simulate melting process using VOF model. Pcm is solid phase initialy. Upper part of the solid there is air. They do not mix eachother. Natural convection is active. My primary phase air, secondary phase is pcm (phase change material). I have some questions to be sure about my model.
First, I do not define interface between air and pcm. Mean, There are 3 cell zone: air, fin ,pcm but I do not create name selection for this interface in meshing. Is it ok?
Initial condition of Wholesystem temperature is 293K, but air temp is 300K. how to set air temp ?
For cell zone condition, all cell zone (air, pcm, fin ) show mixture. Also for example, if I change pcm to phase2, all of cell zone change to phase 2
Only for secondary phase (pcm), I patch within fluent by adapt-region-mark then patch. Ok? Value of volume fraction should be 1 or 0 while patching?? I am confused. Initialy pcm is solid.
For initial values phase-2 volume fraction is 0. Ok?
I did some iteration for a short time to check model. For results, in graphics-countors I can not see total temperature for phase 1 and 2 only entalphy values I see for phase1 and 2.
Also countors of solidification/melting it shows only mixture. Mixture show what?
Any interaction should I use like surface tension etc.
Thanks for your help.
thermal energy is offline   Reply With Quote
HELP! UDF sinusoidal wave, VOF model, porous face! A8anato_psofimi FLUENT 2 November 10, 2009 15:42
free surface of VOF and melting model? wanghong FLUENT 3 March 13, 2006 10:57
help needed for vof model yan FLUENT 3 December 16, 2005 02:17
Difficult BCs about Freesurface Simulation by VOF Yongguang Cheng FLUENT 0 September 19, 2003 08:39
