May 30, 2013, 06:35 |
VOF no interface
Mat
Rep Power: 14 |
Hi everybody,
I'm doing a VOF simulation with Fluent and here's my problem : The volume fraction is a variable equal to 1 in the primary phase and 0 in the secondary phase. When the value is between 0 and 1, the cell is crossed by the interface. An approximation of the interface position is thus obtained with alpha = 0.5. Right ? In my domain, I have volume fractions from 0 to 0.4, with very large area of non-zero volume fraction. What does it means ? I can understand that the interface could be a bit diffuse, but not so much. And in addition the volume fraction does not go above 0.5 ? Where is the interface thus ? Are these results reliable ? In fact, it looks like a Euler-Euler simulation. (The continuity and momentum residuals are ok.) Thanks for your help ! Best, Mat |
June 6, 2013, 06:33 |
OJ
Rep Power: 20 |
Few images will help. But yes, VOF is typically used to resolve the interfaces between two fluids distinctly separated, unlike Euler models which work with typically dispersed fluids.
OJ |
June 11, 2013, 11:52 |
Mat
Rep Power: 14 |
Thank you for your answer !
At the moment, I'm not sure if I can show the geometry, sorry. But my question is simple : If the volume fraction does not reach 0.5, does it means that Fluent is not able to capture the interface and thus also that the computation is non-realistic ? Best, Mat |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
