June 27, 2011, 12:47 |
GMO _problem from rotational angle
jiko
Rep Power: 16 |
I have a GMO rocking around fixed(Y) axis. It is observed that when the rotational angle is all positive or all negative then the oscillating x force is in reasonable range. but when this rotational angle oscillates from -M to +M value the resulting x-force is nearly zero . why? Please suggest something to fix this issue. thanks
Here the GMO is moving under prescribed sinusoidal velocity. |
June 27, 2011, 21:05 |
#2 | |
michael barkhudarov
Rep Power: 18 |
I am not sure I grasp the geometry of the motion. Do you have an prepin please? |
June 29, 2011, 07:04 |
jiko
Rep Power: 16 |
Thanks M,
Here is the prepin file attached. the phase of 270degree is to rock the GMO evenly on both sides of the initial position. observe the x-force for 0 phase and for 270phase. thanks. waiting for your reply. J |
June 30, 2011, 00:12 |
michael barkhudarov
Rep Power: 18 |
Thanks for the file. The first thing I'd suggest is not using the GMRES implicit viscous solver. It does not produce reliable solution and needs further work. In fact, I don't think you need an implicit viscous solver at all. An explicit solver is always better if it does not limit the time step too much. In your case the fluid is water, so I am sure the time step stability is controlled by convection rather than viscous dissipation.
Let me know if it behaves differently with the explicit sovler. |
July 1, 2011, 06:18 |
jiko
Rep Power: 16 |
Thanks Michael,
Under Numerics--> the allowed option for pressure solver is only Implicit but for viscous stress I did switched it to the suggested Explicit. But unfortunately the problem is still there. Could you suggest another remedy Please? even if you try x-translation (of any GMO) and put the initial phase as 270degree. the unrealistic x-force can be observed. |
July 1, 2011, 18:52 |
michael barkhudarov
Rep Power: 18 |
i'll check it out this weekend
July 12, 2011, 10:27 |
jiko
Rep Power: 16 |
Hi Michael, Just a gentle reminder that I am still waiting to hear from you.
Thanks. |
July 12, 2011, 15:04 |
michael barkhudarov
Rep Power: 18 |
Yes, sorry, will check it out as soon as I can.
Mike |
July 12, 2011, 20:59 |
#9 |
michael barkhudarov
Rep Power: 18 |
Jiko, I ran it as you sent me and get a pretty substantial force in the x-direction. So far it is just short of 5 seconds. See the plot
July 18, 2011, 06:11 |
#10 |
jiko
Rep Power: 16 |
Thanks for your time Michael, I wonder why on my PC it turns out to be much different. I would be grateful if you could send me the prepin used for these results from your end.
thanks |
July 29, 2011, 16:59 |
#11 |
michael barkhudarov
Rep Power: 18 |
Jiko, it is the same file you sent me. I ran it with version 10.0 of FLOW-3D. Version 9.4 should give the same results.
August 1, 2011, 05:17 |
#12 |
jiko
Rep Power: 16 |
thanks Mickael, so its mean that version 10 solves my problem.
August 15, 2011, 12:51 |
#13 |
michael barkhudarov
Rep Power: 18 |
I hope so...
InterFoam contact angle | JoaoMiranda | OpenFOAM Running, Solving & CFD | 7 | October 20, 2016 07:27 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
[ICEM] Rotational periodicy setup | Procyon | ANSYS Meshing & Geometry | 0 | April 30, 2011 08:55 |
Normal vector, slope and aspect angle | g_niro | Main CFD Forum | 0 | February 2, 2011 18:24 |
Proper output of angle of attack in CFX post | Kevin | CFX | 3 | October 18, 2006 13:18 |
