April 14, 2011, 11:28 |
force on gmo with prescribed motion
jiko
Rep Power: 16 |
I am analysing vertical force of water on a vertically (z, axis of gravity) oscillating GMO. the amplitude and frequency of the gmo is prescribed.
now since it is oscillating in still water I thought the initial force would be 0 at 0 time. but it is not. could someone please explain why the vertical force is not zero at zero time. or is something wrong in my simulation setup ? thanks in advance. |
April 26, 2011, 10:00 |
#2 | |
jiko
Rep Power: 16 |
it's quite surprising that no one seems to have any idea of buoyancy |
July 25, 2011, 13:45 |
mohammad hossein shfiei
July 25, 2011, 17:02 |
Jeff Burnham
Rep Power: 17 |
Force is calculated from acceleration (of the water on the object). If there is gravity, then the force is non-zero. If there is motion, then the force is non-zero. At t=0, when using the GMO harmonic oscillation model, acceleration is non-zero. Therefore, the initial state of the fluid is non-zero: although it is not 'in motion' (no advection is occurring), it is accelerating, correct? Therefore, the force on the GMO is also non-zero. Note that velocity works the same way, since it is also following a harmonic oscillation: GMO velocity at t=0 is not zero.
July 29, 2011, 00:21 |
#5 | |
michael barkhudarov
Rep Power: 18 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Prescribed object motion and 6DOF | vinz | OpenFOAM Running, Solving & CFD | 1 | September 23, 2013 07:37 |
DEFINE_CG_MOTION and pressure force | Teo Fumagalli | FLUENT | 0 | April 11, 2008 10:25 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
Automatic Mesh Motion solver | michele | OpenFOAM Running, Solving & CFD | 10 | September 26, 2005 08:21 |
