Home > Forums > Software User Forums > FLOW-3D
running flow-3d in command line (linux)
Like Tree1Likes
  • 1 Post By dieter
Old   April 19, 2010, 10:48
Default running flow-3d in command line (linux)
Dieter Vanneste
dieter is on a distinguished road
I suffered a small problem when trying to run flow-3d from the command line in linux. I use the custom double solver with a user definable namelist (usrdat). When trying to preprocess the prepin file, the preprocessing process gets stuck (a number 1 is shown in the command line).
However, when running the same input file in the gui, the preprocessing is completed in a normal way. Anyone has a clue how to solve this?
thanks in advance
Dieter
2697960712 likes this.
dieter is offline   Reply With Quote
Old   April 20, 2010, 09:22
Dieter Vanneste
The problem can be solved by explicitly defining the solver version, in this case use:
export F3D_VERSION=prehyd
Old   May 2, 2010, 17:11
michael barkhudarov
MuxaB is on a distinguished road
Thank you, Dieter
MuxaB is offline   Reply With Quote
Old   June 12, 2016, 05:14
yanhua.li is on a distinguished road
Originally Posted by MuxaB View Post
Thank you, Dieter
I am also find this problem. I want to know whether the probelm is solved? and how to solve.
yanhua.li is offline   Reply With Quote
Old   June 13, 2016, 11:38
michael barkhudarov
There is really no problem. There are two places where the solver resides in a standard FLOW-3D installation: $F3D_HOME\prehyd\hydr3d and $F3D_HOME\double\hydr3d. The prehyd folder contains the user customized executable.
The environment variable F3D_VERSION points to either double or prehyd, with the default being double. You either need to set F3D_HOME=prehyd in the command windows you are working in, or set it in the global setting script, e.g., .cshrc, in which case it will be set automatically every time you open a command window.
Old   July 31, 2016, 22:56
COMMAND LINE SUBMIT IS OK。
because of the version difference, the some parameters in prepin file is changed.
change them and resubmit.
Old   November 18, 2024, 07:45
Default Hello, may I ask why I still have that problem whI set the F3D_VERSION=prehyd.
weiraojun
2697960712 is on a distinguished road
Hello, may I ask why I still have that problem when I set F3D_VERSION=prehyd
2697960712 is offline   Reply With Quote
Old   Yesterday, 16:06
Default error message
michael barkhudarov
What is the error message you see in the prprerr file and what version of FLOW-3D are you running?
command line, preprocessor, runpre
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
UDF error from Windows to Linux manu FLUENT 3 January 10, 2008 05:02
compatibility problem of UDF on LINUX manu FLUENT 4 December 19, 2007 05:58
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Question on 3D potential flow Adrin Gharakhani Main CFD Forum 13 June 21, 1999 06:18
