Home > Forums > Software User Forums > FLOW-3D
sediment scour model, scalars OR mass particles?
Like Tree1Likes
  • 1 Post By MuxaB
Old   October 12, 2009, 06:38
Default sediment scour model, scalars OR mass particles?
Atiieh Rostami
ati_ros61 is on a distinguished road
I want to model the sedimentation process in a settling tank. I will have some suspended concentration and I want to investigate the settling efficiency in the settling tank. I read the Flow-3d Help file and I see that I should use the sediment scour model, scalars and mass particles together, But I’m not sure about that!
Are these models, good for my purpose or not? And also I found some parameters (e.g. IFDIS(n) and ISCTYP(n) in Namelist FL; ISCOUR1 and ISCOUR2 parameters in the SCALAR namelist) but I don’t know where should I introduce these parameter in GUI.
How can specify the concentration of bed load and suspended load (separately) in initial and boundary conditions.
ati_ros61 is offline   Reply With Quote
Old   October 20, 2009, 00:51
michael barkhudarov
MuxaB is on a distinguished road
Hi Atiieh,
I don't think you should be using particles; they are only good for very low concentrations of sediment. The scour model should be adequate. There is an example test problem in the directory Examples in the installation folder, called 'scour'. It has all the settings you need, including setting the initial packed bed.
In older versions of FLOW-3D you may need to enter much of the stuff into the prepin file using the text editor. Version 9.4 has a new, multi-sediment scour and bed-load transport model. Much easier to use. I hope you can get your hands on it.
Michael
Flowdy likes this.
MuxaB is offline   Reply With Quote
Old   November 17, 2013, 12:17
Flowdy
Flowdy is on a distinguished road
Hi everyone.
I´m doing exactly what Atiieh was doing some years ago.
I have a problem because THE SEDIMENT CONCENTRATION IN THE TANK SEEMS TO INCREASE WITH NONSTOP. My theory is that just the water is flowing out of the tank but not the sediments. How can I correct that? I need that the water with their respectively concentration of sediments go out of the tank.
The BC of the outlet is volume flow rate or Specified velocity (I can do any of them). I´m working with “sediment Scour model” but not with “Particles model”
Could some please help me?
Flowdy is offline   Reply With Quote
Sediment Scour Ghirghidov FLOW-3D 7 October 20, 2009 04:21
DPM: How to find out the trapped particles mass Prashant Main CFD Forum 0 October 24, 2007 13:03
Question on Sediment Mass Conservation Scheme Wen Long Main CFD Forum 0 July 6, 2004 16:45
How to model collision of the transport particles Wang FLUENT 0 March 6, 2001 09:45
Two-phase mass conservation ? Michael R. Rasmussen CFX 3 September 1, 2000 09:36
