Home > Forums > Software User Forums > FLOW-3D
Batch Job Runing under Linux Environment
Like Tree1Likes
  • 1 Post By ck5285
Old   April 21, 2009, 05:48
Thumbs down Batch Job Runing under Linux Environment
ck5285 is on a distinguished road
Hi
Is anyone know how to run F3D in batch job mode under Linux environment?
2697960712 likes this.
CK
ck5285 is offline   Reply With Quote
Old   April 21, 2009, 14:11
H.C
H.C is on a distinguished road
#! /bin/sh
cd simulation_directory1
runpre
runhyd
runpre
runhyd
not sure if its what you want. btw, if you r using v9.3.x, you can put all simulations in a workspace and then simulate the workspace. the simulations will be launched one at a time in the order.
H.C is offline   Reply With Quote
Old   April 21, 2009, 22:58
Hi HC
yes this is what i'm looking for, but what file format that i should write this command? bat or dat? i'm using v9.3.1 but would like to run job in netbatch processing.
CK
Old   April 22, 2009, 11:35
H.C
it should be just in text format, as it is a script. you can create it by using either vi or some other text editor.
After the file is written correctly, type in "chmod u+x filename" to make the file executable.
Old   April 22, 2009, 22:15
Hi HC
some clarification as below.
1. it should be simulation_directory1 & simulation_directory2 right?
2. btw what is #!/bin/sh command stand for? it is F3D program command?
3. This command when put in text editor it don't necessary to be the same folder/directory as the model directory right?
_______________________
#! /bin/sh
runpre
runhyd
cd simulation_directory1 (should be simulation_directory2 right?)
runpre
runhyd
Old   April 22, 2009, 22:29
H.C
1. yes, they should be different simulation directories.
2. it is not a flow3d command. it is the shell command normally included in the linux distribution.
3. no. you can save it anywhere you may.
Old   April 23, 2009, 00:44
HC
thanks and if i run in bath mode can i still change the solver option through PEEK program?
Old   April 23, 2009, 10:07
michael barkhudarov
MuxaB is on a distinguished road
9.3 has a script provided for running batch jobs. The script is call runbatch and located in the local directory in $F3D_HOME. The Manual describes how to use it. You create a text file with the paths to all the prepin files, relative or absolute - one prepin per line, then run
> runbatch <file>
It will run all the jobs sequentially.
Michael
MuxaB is offline   Reply With Quote
Old   April 23, 2009, 11:46
H.C
i am not sure if you can change the runtime options by using peek program. but you can try creating/modifying hd3opt file and create a text file named "HYdr3D_SIgnAL.dat" and put the number 8 in it.
Old   April 28, 2009, 21:47
HC and Michael
Thanks for the info.
FLUENT Batch job Saravanan FLUENT 11 May 14, 2014 17:47
Running Job in Batch mode (EFD) Nick Sessions FloEFD, FloWorks & FloTHERM 0 April 16, 2008 17:44
How to create Batch job for CFX-10 in Linux OS siv CFX 2 March 21, 2006 04:38
Linux: when the job suddenly stops working. Stevie Wonder CFX 3 August 15, 2004 19:36
batch job under linux Marcio Siemens 10 August 18, 2003 06:48
