September 12, 2024, 16:58 |
Define Simulation Time - Volume flow rate BC
Evangelos Fotopoulos
Hello to all
I'm working a model of a curved weir where i need to enter a Volume Flow Rate Boundary Condition at Ymax. The problem is that my Volume Flow Rate hydrograph has a duration of 72h=104400sec. How can i manage to run this simulation. Is it right to set a Finish time of 104400sec in the Finish time window in Global tab?.I see that the default value of software is 100 sec in which my flow hydrograph hasn't even reached it's peak. So what can i do about it? Thanks in advance |
Postprocess: sampleDict works but creates no output folder | shock77 | OpenFOAM Post-Processing | 14 | November 15, 2021 08:27 |
SU2 7.0.7 Built on CentOS 7, parallel computation pyscript mpi exit error? | EternalSeekerX | SU2 | 3 | October 9, 2020 18:28 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
same geometry,structured and unstructured mesh,different behaviour. | sharonyue | OpenFOAM Running, Solving & CFD | 13 | January 2, 2013 22:40 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
