Setup to determine force exerted on a solid structure by a flowing fluid |
June 11, 2024, 09:01 |
Dekoya
I am simulating a flood flow and need to determine the time history of the drag force as it flows across an obstacle. After setup, the output definition gave options like fluid velocity, hydraulic data etc., but there is no option for force. I need help on how to define output for force. Your kind guidance on this will be appreciated.
June 11, 2024, 09:32 |
Henry
To determine the force exerted on a solid structure by a flowing fluid, you can set up an experiment or a simulation that measures this force. https://wordleunlimited.fun
basket random |
June 12, 2024, 07:04 |
Rep Power: 12 |
First you need to check additional outputs from Outputs tab. Then, after calculation, you can check your forces at the probes tab under the results section.
[solids4Foam] FSI case does not converge, foam extend 4.0 | MFWilliams | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 12 | May 13, 2022 08:35 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Calculating the force exerted on an object from fluid pressure | amrbekhit | CFX | 1 | January 30, 2011 16:38 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
