Home > Forums > Software User Forums > FLOW-3D
Water on particular particular sections are not visible
Like Tree1Likes
  • 1 Post By kylas
Old   May 23, 2024, 04:00
Default Water on particular particular sections are not visible
kyla
kylas is on a distinguished road
Supposedly, the water should flow throughout the channel. But in the result, the water seems to be gone on some sections. What do you think the reason behind this?
kylas is offline   Reply With Quote
Old   May 28, 2024, 15:03
Sehroosh
MSM1985 is on a distinguished road
Is the slope of channel is same for whole reach ? If yes either the slope is more or less than critical slope ?
MSM1985 is offline   Reply With Quote
Old   May 28, 2024, 22:45
chelsey
heyzel is on a distinguished road
same problem
heyzel is offline   Reply With Quote
Old   May 29, 2024, 01:13
kyla
@Sehroosh Thanks for the response.
No, the slope of the channel varies. I've noticed that the water usually disappears in sections with steeper slopes. Is there a way I can solve this?
Old   May 29, 2024, 01:49
Sehroosh
Steeper slopes means lesser depth and higher velocity. In the steeper slope areas, you need to refine the mesh in such a manner that your mesh size is smaller than your anticipated flow depth. If your mesh have atleast 3 cells in your anticipated flow depth, this issue will be resolved.
Old   May 29, 2024, 02:03
kyla
Great! Thank you so much for your response. I'll try to change the mesh size to improve the results. Thanks again!
Old   May 29, 2024, 04:32
koful is on a distinguished road
Hi.
Mesh resolution is important bu It is also a visualisation problem. These areas have fluid and solver solves it. Bu the default isosurface value is 0.5. If any cell has fluid fraction below 0.5, it does not shown at render images. You can reduce this value from Results section. It should be something like "contour value". you can delete "Auto" and type 0.2 or 0.1
koful is offline   Reply With Quote
Old   May 29, 2024, 04:51
kyla
Originally Posted by koful View Post
Hi.
This! Thank you so much for this tip. Super helpful, I solved the problem in a minute. Thanks a lot!
koful likes this.
animation, flow 3d, flow 3d hydro, flow 3d post, spillway
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Coupled Heat and Mass Transfer Mecroob OpenFOAM Running, Solving & CFD 1 July 12, 2020 20:24
water velocity and water velocity in stationary frame of a water jet zehab CFX 0 May 11, 2020 04:17
No liquid water exist in my Fuel Cell simulation fatchang FLUENT 19 October 15, 2018 15:27
All effects to consider in high pressure water flowing in thin sections enginpower System Analysis 0 September 20, 2016 13:13
