Home > Forums > Software User Forums > FLOW-3D
Calculate the depth of the scour hole around the bridge base?
Like Tree4Likes
  • 1 Post By sajad.mojatahedi
  • 1 Post By MSM1985
  • 1 Post By MSM1985
Old   January 16, 2024, 08:27
Unhappy Calculate the depth of the scour hole around the bridge base?
sajad mojtahedi
sajad.mojatahedi is on a distinguished road
Hello
Which option should I choose in the analysis section of flow 3d software to get the depth of the scour hole, of course there are similar options, but they do not give the desired output (I put the similar options in the attachment)!!
toantu likes this.
sajad.mojatahedi is offline   Reply With Quote
Old   January 17, 2024, 01:49
Sehroosh
MSM1985 is on a distinguished road
Hi. Usually 'Packed Sediment Elevation Net Change' should do the job. Just add/subtract the value obtained from Flow 3D simulation, from NSL which you have used as input geometry.
toantu likes this.
MSM1985 is offline   Reply With Quote
Old   January 17, 2024, 03:14
sajad mojtahedi
Hello, thanks, I did what you said and sent the result in the attachment, unfortunately I didn't get the desired result, what do you think is my mistake? And about the subject you said (Just add/subtract the value obtained from Flow 3D simulation, from NSL which you have used as input geometry.) How should I do this?
toantu likes this.
Old   January 17, 2024, 06:54
Sehroosh
You can view it in 2D mode as shown 'start' and 'end' simulation picture in attached file. Alternatively you can use 'Text Output' option to extract data in excel file, to check scour depth numbers while adding/subtracting it from initial NSL profile.
toantu likes this.
Old   January 17, 2024, 09:15
sajad mojtahedi
Hi, thanks
flow 3d post
maximum scour depth InêsM FLOW-3D 0 May 23, 2018 18:58
[snappyHexMesh] How to define to right point for locationInMesh Mirage12 OpenFOAM Meshing & Mesh Conversion 7 March 13, 2016 15:07
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
OpenFOAM 1.6.x - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 68 April 22, 2013 12:03
Scour and flow field evolution around a bridge pier with collar Amartya Kumar Bhattacharya Main CFD Forum 1 November 20, 1999 15:55
