November 24, 2023, 09:21 |
Main files in flow3d
pouya
Rep Power: 9 |
Hi everyone
I wanted to know what are the main simulation files in Flow3d? Due to storage space limitations, I want to delete the simulation results file, but save the main simulation files. I would be grateful if you could tell me the names and uses of these files. |
November 27, 2023, 01:02 |
Sehroosh
Rep Power: 7 |
Hi. You can save "prepin" file with STL files which are input of the model. Rest you can delete. Infact the result file "flsgrf" has the largest size. Just deleting the said file can create enough space, but you have to run the model again when you need to see the results.
flow3d post, main files, prepin file, workspace file |
How to convert .trn files to .cgns files | cyln | CFX | 5 | October 21, 2018 00:25 |
problem compiling with header files | jreiter164 | Fluent UDF and Scheme Programming | 2 | August 14, 2015 18:31 |
How to open old mesh cmdb files in ANSYS CFX v13.0 ? | Sudharshani | CFX | 2 | May 12, 2013 23:13 |
Compiled library vs. inInclude Files, DSMC solver crashes after run | GPesch | OpenFOAM Programming & Development | 8 | April 18, 2013 08:17 |
Converting ANSYS CFX files to Fluent files | Martin S. Rasmussen | FLUENT | 3 | January 30, 2007 16:08 |
