Home > Forums > Software User Forums > FLOW-3D
scour in flow3d
Like Tree1Likes
  • 1 Post By RPJones
Old   June 2, 2023, 07:19
Default scour in flow3d
pouya
pouy@ is on a distinguished road
I have one scouring problem for bridge piers with collared plates in flow3d
I have simulated that in the 23rd second of the message the solution is nearly steady ,It repeats for me every 5 seconds, but at least until 100 seconds when I repeated the process of continuing the program, the 50% change in the amount of scour was still happening. Considering the very long time that the software takes to solve the problem (several days), should I ignore the above message and continue the program with more seconds (for example, up to 300 seconds) until the amount of scouring changes is close to zero or is there a problem and I have to modify the Computational models again?
Thank you for guiding me in this problem.
pouy@ is offline   Reply With Quote
Old   June 9, 2023, 16:12
Ryan Jones
RPJones is on a distinguished road
Originally Posted by pouy@ View Post
The simulations bases its guess on the solution being at steady state based on the total mass, average mean kinetic energy, average mean turbulent energy, and average mean turbulent dissipation. These values are evaluated for a 1% change over a given time windows (1/10 of simulation time) and then it makes the suggestion.
Running for a longer simulation will allow you to see how the scour evolves over time. Unless the hydraulics develop a condition that drops the bed shear low enough to stop scouring, you will continue to see scour as long as the simulation is running or until you run out of material that is allowed to scour.
pouy@ likes this.
RPJones is offline   Reply With Quote
Old   June 14, 2023, 04:41
pouya
thanks man
bridge pier, flow3d, nearly steady, scour, step time
FLOW3D POST: Query Scour depth/bed elevation at predefined points hiramani12 FLOW-3D 1 October 11, 2023 03:08
CAESES and FLOW3D connection lamnguyen11b2 FLOW-3D 3 October 31, 2022 02:31
How to improve the lateral propagation of scour hole (3D) sycst911 FLOW-3D 2 April 29, 2014 23:07
Scour around vertical cylinder pyxbird FLOW-3D 5 December 25, 2013 03:28
how to set joints in flow3d gxwdaq FLOW-3D 1 March 12, 2011 18:45
