Home > Forums > Software User Forums > FLOW-3D
velocity Contours
Like Tree1Likes
  • 1 Post By MSM1985
Old   February 28, 2023, 16:32
Default velocity Contours
Eli
Elaheh 1995 is on a distinguished road
Hello everyone
I hope you are doing great
I have a question about the velocity contours.
as you can see in the picture I am modeling an open channel spillway with a double gate. to analyze the results of the simulation I generated some 2d cross-sections in the x direction.
my problem is that the velocity near the walls and bottom of my channel is not zero or near zero.
my initial velocity is 324cm/s in the x-direction. and my boundary conditions for the spillway are as follows
xmin= velocity 324cm/s
xmax= pressure outflow
ymin, ymax and zmin=wall
zmax= pressure with fluid fraction=0
I have tried refining mesh, (initially, it was 5cm, now it is 2cm) but so far it is not working.
if anyone could help me with this problem I would really appreciate it.
Elaheh 1995 is offline   Reply With Quote
Old   March 1, 2023, 07:02
Sehroosh
MSM1985 is on a distinguished road
Almost zero velocity near wall and bottom is for ideal channel, but might not be true in real life problems (see picture). All numerical models take wall friction effect but surely show some velocity near wall and bottom. If you essentially want to see that effect then you just need to model bottom or wall with superfine mesh. Otherwise there would definitely be some velocity around solid surfaces during numerical modeling.
Elaheh 1995 likes this.
MSM1985 is offline   Reply With Quote
Old   March 1, 2023, 07:11
Sehroosh
Alternatively you can increase surface roughness to such a value that velocity becomes zero ( tried in HEC RAS). But as a hydraulic engineer, i shall consider it incorrect as it will not be a realistic condition.
Old   March 1, 2023, 13:50
Eli
Thank you for the explanation, I guess it makes sense, can you by any chance tell me some references so I can justify it for my supervisor?
thanks a lot.
Old   March 2, 2023, 03:18
Sehroosh
The observations provided on page # 330 & 331 of the book "Hydraulics & Its Applications by A.H.Gibson", supports above argument. To know how numerical model computes velocity profile, refer to Chapter 1 of book "Numerical Modeling in Open Channel Hydraulics by Romuald Szymkiewicz".
Streamlines colored by velocity contours Andrea1984 Tecplot 3 December 30, 2022 09:20
Velocity contours and velocity profiles for a rotor Waketraveller FLUENT 0 February 20, 2021 00:32
kindly help me .. i have and error at line number 147.. m zubair Fluent UDF and Scheme Programming 0 February 10, 2019 12:25
Contours of velocity in pump aja1345 FLUENT 2 February 18, 2014 02:54
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
