January 30, 2023, 05:16 |
How to have a constant flow in a spillway?
Ali Ghafouri
Rep Power: 3 |
hey everyone, I'm modeling flow in a bell mouth (morning glory) spillway and I want a specific flow rate and I can't reach that. for instance I want a 600 m3/s volume flow rate but I can't have it fixed at that number it varies like from 500 to 700 m3/s.
any tip on that? I have used volume flow rate and specified pressure as boundary conditions and the results were similar. |
January 30, 2023, 07:31 |
Sehroosh
Rep Power: 7 |
The probable reasons of fluctuating flow values could be:
i) The results might be extracted before steady state. The model finish time should be enough to reach simulations to a steady state. ii) A finer mesh will definitely increase the accuracy. iii) Flow measurement should be made where there flow is almost uniform. |
January 31, 2023, 15:15 |
#3 | |
Ali Ghafouri
Rep Power: 3 |
Yes I do reach steady state and the results are converged as well and I have tried a better mesh but it didn’t get any better |
February 1, 2023, 03:19 |
Sehroosh
Rep Power: 7 |
While modeling a morning glory spillway as shown in the picture, initial condition is also important. Do not fill pipe completely. Instead give time dependent boundary condition where waterlevel increases from reservoir floor to headwaterlevel. This will prevent spillway from drawing additional water as the mouth of morning glory does not flow full.
February 1, 2023, 05:07 |
#5 | |
Ali Ghafouri
Rep Power: 3 |
Thank you for your time |
Constant mass flow rate in channel flow LES | vishwesh | OpenFOAM Running, Solving & CFD | 4 | May 10, 2018 10:10 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
Is there a correlation for Nu number in laminar pipe flow with constant wall heat flu | Shomaz ul Haq | CFX | 5 | June 19, 2017 09:04 |
Interfoam - Real world Geometry with constant inlet flow | bdh1103 | OpenFOAM Running, Solving & CFD | 0 | February 10, 2016 15:54 |
Flow Over a Spillway | Nicopep | OpenFOAM | 1 | October 21, 2009 05:48 |
