How can I define surface roughness of packed sediment? |
Limin Sun
Rep Power: 0 ![]() |
Is there any way to define surface roughness or drag coefficient?
I am building a model to simulate sediment transportation on the marsh platform. So the surface roughness derived from the D50 is too small for the marsh platform. I have noticed that the "surface roughness" for the packed sediment component is inactivated. How can I activate the "surface roughness"? Any comments or suggestions will be highly appreciated! |
Sehroosh
Rep Power: 7 ![]() |
Surface roughness is used to describe the surface undulations of a structure. Sediment itself is a wrinkle/ripple with so called D50. You already defined it in physics > sediment properties. That's why surface roughness will be replaced by packed sediment fraction option for components defined as 'Packed Sediment'.
Limin Sun
That makes sense! I really appreciate your explanation. In that case, I will change the surface properties for all the packed sediment components. The aim is to model sediment dynamics on the marsh platform. I could not find a way to incorporate unsubmerged vegetation in my model. Do you have any suggestions to change the surface properties of the marsh only?
Sehroosh
Surface properties of any object can be changed if you define it as 'solid' rather than 'packed sediment'.
packed sediment, sediment scour, surface roughness |
Surface Roughness Drag Analysis | shindiregita | FLUENT | 0 | May 30, 2020 02:32 |
In flow3d, How is sediment species flow rate through flux surface and mass of suspend | Sav | FLOW-3D | 0 | March 13, 2020 03:28 |
Surface Roughness Problem | hydr_eng1805 | FLOW-3D | 2 | December 15, 2014 08:29 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
Free surface boudary conditions with SOLA-VOF | Fan | Main CFD Forum | 10 | September 9, 2006 12:24 |
