January 20, 2023, 12:15 |
velocity profile in flow3d
Eli
Rep Power: 4 |
hi there everyone
I am modeling an open channel spillway with flow3d and it is almost functioning but the problem I have is that the velocity profile is not as desired (it is not zero near the walls and bottom of the channel and it is not maximum near the surface of the water) the boundary condition that I have used is as follows: xmin=pressure with fixed fluid elevation xmax=pressure outflow ymin/ymax and zmin=wall zmax=pressure with fluid fraction=0 does anyone know what should I do to have ideal velocity profiles? thanks a lot 20 jan.jpg |
January 23, 2023, 02:03 |
Sehroosh
Rep Power: 7 |
As seen from figure, flow is controlled at inlet by orifice openings, so its just like bottom outlet spillway (not traditional open channel flow). Due to two openings, flow is distributed in two paths. This effect will diminish some distance downstream of the openings. As 'red contours' are getting closer, either refined mesh size or increasing downstream channel length will show maximum velocity contours in middle of channel. Maximum water surface velocity occurs 0.05 to 0.25 of the depth for channels. Also its better to extract the results when flow is nearly steady.
Boundary conditions are OK. |
January 23, 2023, 12:10 |
#3 | |
Eli
Rep Power: 4 |
flow3d, spillway, velocity profile |
Is it possible the velocity profile changes in the fully-developed turbulent flow? | czx0415 | FLUENT | 0 | July 9, 2020 16:25 |
[UDF] Relative coordinates in logarithmic velocity profile | cfdworker | Fluent UDF and Scheme Programming | 25 | July 13, 2017 03:44 |
InterFoam - Validation for velocity profile in simple channel | me.ouda | OpenFOAM Running, Solving & CFD | 0 | October 19, 2015 06:42 |
[boundary condition] logarithmic velocity profile | cfdworker | FLUENT | 2 | April 17, 2009 23:36 |
Prescribed inflow velocity profile - how to? | Alan | Main CFD Forum | 10 | October 28, 2005 12:14 |
