Home > Forums > Software User Forums > FLOW-3D
pump function in flow3D
Like Tree1Likes
  • 1 Post By MSM1985
Old   November 23, 2022, 17:10
Default pump function in flow3D
Eli
Elaheh 1995 is on a distinguished road
hello, i hope you are doing great. i have got some questions about flow 3D and i need your help
1) i want to model a channel that has a tank of water and there is a pump that sends water to the channel constatly. i don't know how to define the pump function.
2) also i want a finer mesh near channel and coarser mesh for tank and i need the mesh to gradually increas but i have no idea how to do that either.
i would really appreciate if you could help me with my questions.
thanks in advance
Elaheh 1995 is offline   Reply With Quote
Old   November 24, 2022, 12:07
UK
redlemon44 is on a distinguished road
This shows the pump function:
https://www.youtube.com/watch?v=ptF1U4PXaFs
FLOW-3D’s new axial pump model allows users to mimic the net effect of an axial pump in their simulations. There are two options with respect to the pump behavior. The first option is to prescribe either a volumetric flow rate or a flow velocity through the pump so that the fluid is moved at the specified rate. This option is appropriate when an operating flow rate is provided for the pump. The second option provides a more complete definition of the pump operation based on a pump performance curve
redlemon44 is offline   Reply With Quote
Old   November 30, 2022, 05:17
Sehroosh
MSM1985 is on a distinguished road
For discharge feeding, you can either use a pump function or discharge boundary condition at the inlet of channel, whichever is more closer to the real problem.
For meshing, you can use a nested mesh block. 1st mesh can be coarser and covers whole domain. 2nd mesh block should be confined to channel and must be finer. The ratio of cell size size between 2 mesh blocks should be 1:2.
I am not aware if we can provide gradually increasing meshes in flow 3D. If that's the case, it will be tricky and computational intensive.
Elaheh 1995 likes this.
MSM1985 is offline   Reply With Quote
Old   November 30, 2022, 13:13
Eli
thanks for your response, it makes sense. I will try it
Old   November 30, 2022, 13:40
Eli
thanks MSM1985, the meshing explanation was clear to me, but I will need more help with the pump function. should I design a pool so that water could be pumped from it? or should I create a specific component like a cylinder that can be a pump? or I should copy my whole geometry and define it as a pump in the (Fan/Impeller and Pump section). and about the boundary condition do you mean pressure by "discharge boundary condition" or else?
Old   December 1, 2022, 06:17
Sehroosh
As you showed in the figure, water is entering from bottom of the tank into the channel. In this case, volumetric flow rate at Xmin boundary shall do the job.
But if you want to see axial and swirl flow effects induced by pump, then you have to define a separate component, preferably cylinder (option available geometry widget). Define this component as 'Pump' with pump properties. Such components are called 'phantom' which regulates flow but does not block flow.
Old   December 1, 2022, 12:21
Eli
thanks a lot. it was a really good explanation. I don't need axial and swirl flow so I will modify my boundary condition settings. thanks again you really helped me.
How to use "TDMPRB" function in Flow3D? davids88704 FLOW-3D 0 November 6, 2016 23:47
[blockMesh] Errors during blockMesh meshing Madeleine P. Vincent OpenFOAM Meshing & Mesh Conversion 51 May 30, 2016 11:51
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 06:42
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
Droplet Evaporation Christian Main CFD Forum 2 February 27, 2007 07:27
