November 18, 2021, 12:23 |
water mean level drops in scour simulation
ZHANG H.
Rep Power: 6 |
Hello everyone,
I want to do the scour simulation in wave conditions using FLOW-3D, however, the water level drops quickly when I open the scour model. It won't drop when I don't use scour model. The water level dropping is also happened in the simulation of currents, and it can be sloved by setting the Xmax boundary condition as specified pressure. So maybe scour model will effect the mass conservation of water, however I can't set the Xmax boundary condition as specified pressure in wave conditions because it need to be an outflow condition for wave absorbing. I have no idea and choices to ask this question. Thank you very much! |
November 18, 2021, 19:12 |
Eric Lemont
Rep Power: 6 |
You can try setting the Xmax to a specified pressure, then add the wave absorbing component in the geometry instead of using it as part of the outflow boundary condition (see attached image for setting the wave absorbing geometry type).
November 21, 2021, 23:38 |
#3 | |
ZHANG H.
Rep Power: 6 |
But another problem occurred, when I tested the stabilization of wave simulation that the time step went increasingly smaller, finally nearly smaller than 0.0001s(please see the attachment). It confused me for a long time and this time I don't get any clues about this problem. My wave height is 0.12m, wave period is 1.42s, mean depth is 0.4m in 5th stokes wave. I will be very appreciated if you could give me any help! Thanks! |
Initial water level changes with no prescribed flow in domain for all CFL numbers | pipi | REEF3D | 3 | October 13, 2021 22:49 |
Solid object falling in water tank simulation | cassini83 | CFX | 3 | August 9, 2021 18:05 |
postProcessing to visualize areas touched by water during a sprinkling simulation | TheBigLebowski | OpenFOAM | 0 | August 1, 2021 11:20 |
Ricardo Wave Water Injection Simulation | randomspeedfreak | Main CFD Forum | 0 | April 2, 2015 13:20 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
