Home > Forums > Software User Forums > FLOW-3D
Water in the tank increase
Like Tree1Likes
  • 1 Post By mailoan2306
Old   November 14, 2020, 04:04
Post Water in the tank increase
MAI THI LOAN
mailoan2306 is on a distinguished road
Hi every one,
I am simulating the ship in irregular wave.
I am model the tank include sponge layer with type wave absorbing at the end of the tank.
However, after a long time simulation about 600 seconds (the water growing up every 60 seconds). The water in the tank increase compares with the initial.
So how can fix the volume of water the same as the initial state
The picture has been located in the below links
Thank you so much for your help
Setup picture: https://imgur.com/a/vskWBZ9
The volume of water at the initial state: https://imgur.com/a/4ThDkQO
The volume of water after 600s: https://imgur.com/a/VAmExxj
mailoan2306 is offline   Reply With Quote
Old   November 14, 2020, 11:43
nazrin
M.Nazrin is on a distinguished road
Hi Thi Loan,
What is the boundary condition type at the sponge layer? i believe there is no outflow in the domain thus the water level keep increasing.
M.Nazrin is offline   Reply With Quote
Old   November 14, 2020, 11:51
MAI THI LOAN
Thank you four your answer,
The boundary condition of the outlet is outflow as shown in the below link
https://imgur.com/a/slD5L7C
Old   November 15, 2020, 21:44
nazrin
can you check the mesh flow rate at outflow boundary using analyze tab > probe > mesh dependent history > 'outflow boundary'.
Old   November 15, 2020, 23:31
MAI THI LOAN
Thank you for your reply.
I checked the volume flow rate follow you are recommendation shown in the picture in the below link.
I realize that the volume changed frequently. But I didn't understand. It is different when I use the coupled motion and non-moving the object. For example, when I use non-moving the volume of water not change but when I use coupled motion the volume changes it can lose and grow up in the tank.
Volume flow rate: https://imgur.com/a/GykOmVO
Old   November 16, 2020, 02:55
nazrin
"For example, when I use non-moving the volume of water not change but when I use coupled motion the volume changes it can lose and grow up in the tank."
I am not sure what happen for your case. Supposed, fluid volume should be consistent whether you use non-moving/moving object. Perhaps you should forward this to official support? Sorry for not helping.
What happen if you use moving object without wave absorbing component?
Old   November 16, 2020, 03:11
MAI THI LOAN
No no, I am sorry. I mistook
I checked it again. All cases were changed the volume of water it can be lost or grow up.
I will check in case no-wave absorbing.
Thank you for your advice.
M.Nazrin likes this.
water sloshing in oscillating tank (problem using udf Define_ZONE_MOTION) Tamsu Fluent UDF and Scheme Programming 8 November 24, 2021 01:11
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
Earthquake in a tank of water, how i can use a earthqueake, UDF? RobinReiban Fluent UDF and Scheme Programming 0 March 24, 2019 19:50
coaxial jet flow into an open water tank sreesha FLUENT 0 January 26, 2017 15:29
Best tutorial for water storage tank calaba OpenFOAM Running, Solving & CFD 0 June 1, 2016 11:14
