June 10, 2019, 20:46 |
Solve error time-step too small
Tuan
Rep Power: 7 |
How to fix the error time-step<dtmin. It makes the calculation end. Thanks |
June 25, 2019, 01:43 |
Sehroosh
Rep Power: 7 |
Do following steps:
1) Check the plot of time step vs stability in the simulation window 2) Keep time step smaller than the time step you saw in simulation graph. This can be done in numerics tab under 'Time Step Controls' 3) As solver is iterating a lot and reducing time step, its better to change the 'Covergence Controls' in 'Pressure Solver Options' in Numerics tab. You can increase maximum number of iterations before time step is reduced. This will also prevent dt<dtmin. error |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 16:53 |
Coarse prism layers around a small step | sminder | STAR-CCM+ | 1 | March 19, 2017 18:27 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
time step size too small??? | Lilly | FLUENT | 1 | September 15, 2012 01:51 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 05:03 |
