Home > Forums > Software User Forums > FLOW-3D
problem in sediment scour modeling!!!
Like Tree3Likes
  • 2 Post By John_22
  • 1 Post By D.Abedi
Old   August 19, 2017, 06:26
Unhappy problem in sediment scour modeling!!!
Hydreaulic structures
hamidciv is on a distinguished road
Hello Dear Experts & friends;
i've been working on sediment scour caused by submerged jet using flow-3D software more than one year to my phd thesis. i was faced with the strange problem in my model as the deposition(ridge) is not formed in my model, i've tried everything that has come to my mind to solve this problem, but i didn't succeed until now. A bed made up of uniform sand particles with d50=2.46 mm. i've studied one of the training Flow3d file named "modeling sediment scour(TN 62)" before, where it was written "Limitations of the model are the particle size; large sediment particles".
i'm so confused & don't know what should i do. i would say that there are still problems in the flow-3d sediment transport equation. with regards to my sediment size is coarse, Whether this problem can be due to this? i've used the latest version of Flow3D(v 11.2), Is this limitation still there?
i would appreciate any comments & suggestions you may have.
thanks
hamid
hamidciv is offline   Reply With Quote
Old   October 14, 2017, 07:52
Hossein
John_22 is on a distinguished road
thanks
hamid
Dear user
I think you should do some works, as a first, you should say about your physics and your real conditions? did you define appropriate mesh block? did you create appropriate boundary conditions? have you ever assigned appropriate initial conditions?
Say them more clear and then we can share more.
Best regards
Hossein
John_22 is offline   Reply With Quote
Old   November 2, 2017, 05:07
Davood Abedi
D.Abedi is on a distinguished road
سلام
حمید جان من دقیق متوجه نشدم مشکل چیه؟؟؟ مشکل با کالیبراسیون آبشستگیت داری؟؟ یعنی شکل و محل ابشسگیت اونطوری که میخوای نیست؟؟
hanif pourshahbaz likes this.
D.Abedi is offline   Reply With Quote
Sediment Scour Depth and Sediment Hight hossein_sml FLOW-3D 2 December 31, 2015 03:47
scour sediment model javadrasooli FLOW-3D 2 May 15, 2015 13:23
Sediment Scour model mshotm2000 FLOW-3D 3 March 16, 2011 08:06
Sediment Scour model mshotm2000 FLOW-3D 2 February 4, 2011 04:54
continue the problem with RSM modeling cwflying FLUENT 3 April 28, 2002 08:48
