July 29, 2017, 11:10 |
simulation error
Zahra Mehrad
Rep Power: 9 |
Hi every one
I'm trying to use flow3D to simulate flow over a papaya spillway. But when I run simulation it ends up to a bunch of errors and I don't know what is the problem. I double checked every thing; mesh, geometry, initial condition,... searched every where, read the manual. No result. I will be appreciated if any one can help me. CO2: 32313133 33313132 1 1 0 0 0 95 prep3d 11.1 2712 0 95 ***** level 17 error in subroutine prxput: input error while reading namelist props ***** ***** fatal error ***** |
November 1, 2017, 12:38 |
Martin Liepe
Had the same error
You should check the prepin-file (ctrl+E) for errors. Sometimes F3D adds a comma instead of a point as a separator. |
October 18, 2018, 08:29 |
Inquiry
#3 | |
MRoushdy
Excuse me, I have the same problem and I don not know a logical reason for this.. I tried what you said but if I change anything in the (ctrl+E) window it gives error .. please, how to get over this problem it occurs with every model I do . thanks in advance |
error, flow3d, simulation |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 14:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 08:11 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 21:30 |
