January 12, 2017, 16:54 |
friction coefficient?
Hydreaulic structures
Rep Power: 15 |
hi dear experts
static friction coefficient in what issues can be used? i have many tried to finding it's application in help of the software, but unfortunately i can't find any subject relevant to it. The only thing I could find about it I've given below: The rough component should be assigned a no-slip surface (via a negative static friction coefficient). Is it only applied to simulate the flow in the pipes Or can also be used in open channel? would be grateful for any commnets & introduce reference to it. best regards hamid |
February 6, 2017, 13:21 |
This variable is discussed in the Model Reference->Viscosity and Turbulence ->Wall slipe section of the help manual.
Use a negative value for a no slip surface, and and positive values for partial slip surfaces. Applications where you might want a partial slip are some type of coating inside of pipe. It could use it for a channel application, but not sure for what purpose. As the modeler, you would need to decide if it is correct for your application. |
how to calculate time averaged skin friction coefficient | adilio | FLUENT | 2 | January 28, 2017 06:00 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
the skin friction coefficient error from Fluent | sutthinan | Main CFD Forum | 2 | November 28, 2012 14:03 |
Openfoam friction coefficient differences. | Peter88 | OpenFOAM Post-Processing | 0 | February 8, 2011 11:07 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 09:43 |
