Home > Forums > Software User Forums > FLOW-3D
relation between mass momentum source and mass source in component properties
Like Tree1Likes
  • 1 Post By bfox48
Old   January 11, 2017, 12:38
Default relation between mass momentum source and mass source in component properties
SMY
SMY is on a distinguished road
Hello
I'm trying to model a momentum source but i get confused.
First: i dont know the relation between mass momentum source settings and mass source part that exists in component properties. Should i define the same both of them?
Second: i define every parameter in mass momentum source and mass source(component properties setting) according to the flow rate but the modeled momentum source is not working true visually and the velocity is very low when fluid is emerging.
Please guide me
Thanks for ur attention
SMY is offline   Reply With Quote
Old   January 13, 2017, 04:21
Hydreaulic structures
hamidciv is on a distinguished road
hi smy, unfortunately I have the same problem, i define flow rate in mass momentum source, my velocity simulated is difference with the experimental model,
the difference is about 0.10, i have many tried for solve it, but unfortunately i did not succeed, i dont know where is the problem?
If anyone has experience, please guide us. thanks
hamidciv is offline   Reply With Quote
Old   February 6, 2017, 13:34
brian
bfox48 is on a distinguished road
Mass-sources and mass-momentum sources are two different objects. Mass sources are related to a geometry component, where the mass-momentum sources are special objects that are defined separately.
Make sure that these are well resolved by the mesh. If you only have a few cells resolving them, then it might cause an error in flow rates. It will also cause an error when visually displaying in the 3D tab.
Azmina likes this.
bfox48 is offline   Reply With Quote
Error message: Insufficient Catalogue Size Paresh Jain CFX 33 August 16, 2024 06:09
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
