July 17, 2016, 09:11 |
whch kind of mesh is better for finer mesh??
xu feng
Rep Power: 11 |
As I know two kinds of mesh,gradual mesh(set planes to where finer meshs needed) and nested meshs,which is better,thank you for reply
July 18, 2016, 03:49 |
#2 | |
Reynolds
Rep Power: 10 |
Which is your transition ratio? Which is the biggest cell size? And the smallest one? For me, the main problem of gradual mesh is the mesh quality control. Take into account that your cell aspect ratio should be near 1. This can be a bit difficult with this method (not impossible haha). With nested meshes inter block data is something to take into account also. I´m not sure exactly but I think that Flow3d don’t recommend to use more than 3 mesh block to make transitions… You can check it in the manual! I think that there in not better or worse method, it depends on your application. Take also into account the solver you are using. Is not comparable the mesh size/quality you need for implicit method or explicit one. I think that you can find information on the internet, sometimes…too much...haha Good luck!
A wife asks her husband, a software engineer... "Could you please go shopping for me and buy one carton of milk, and if they have eggs, get 6!" A short time later the husband comes back with 6 cartons of milk. The wife asks him, "Why the hell did you buy 6 cartons of milk?" He replied, "They had eggs." |
[ANSYS Meshing] Combine solid mesh generated in workbench mesh and fluid mesh in fluent meshing ? | RPjack | ANSYS Meshing & Geometry | 2 | August 27, 2015 09:33 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Mesh, Solutions, Model, results | doneatlast | FLUENT | 0 | March 12, 2014 16:18 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 09:36 |
What kind of mesh to use for cylindrical object in channel | nihossain | FLUENT | 1 | November 2, 2011 01:16 |
