Ya Qian
Rep Power: 10 ![]() |
I am simulating a powder (using a sphere fluid region) radiated and heated by a laser beam. the beam source is added in qsadd.f in which I modified rhoe. But the simulation is terminated reporting 'negative fluid temperature'. I check the cell index with negative fluid temperature, and find that the cell is often near the surface in the void region. Anyone can help me? thanks
Ya Qian
By the way, I find that if I change the powder into a plate, simulation is OK. So I guess that the problem may relate to the geometry. But I can hardly find the exact cause nor manage to deal with it.
Asmaa Hassan Abdelhamid
Rep Power: 0 ![]() |
Please , do you know how can i dissapear the negative signs of veloicty in the results of fluent ??
#4 | |
hamed
Rep Power: 4 ![]() |
I also have the same problem and I changed and replaced a qsadd.F file in Flow-3d software v 11.0.4. But the software does not call the code. I wanted to see if anyone could provide me with the Gaussian distribution heat source code that works? I will be very grateful. |
Dan Hawker
I had a similar issue where my simulations terminated reporting 'negative fluid temperature'. I was applying a heat flux to a surface. In my case, all of the negative temperatures were associated with cells that had very small fluid fractions (<0.00001). I was able to fix the problem by only applying heat flux to cells above a certain fluid fraction.
#6 | |
hamed
I have sent you a private message. Please consider it. Thank you very much. |
heat transfer |
[blockMesh] blockMesh error - Negative Volume Block | adoledin | OpenFOAM Meshing & Mesh Conversion | 2 | June 22, 2016 10:44 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 10:51 |
UDF to modify inlet fluid temperature | Vipul_Patel | Fluent UDF and Scheme Programming | 0 | February 22, 2016 21:11 |
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion | faizan_habib7 | CFX | 4 | February 1, 2016 17:00 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
