April 21, 2016, 13:03 |
Flowsight
Ontario
Rep Power: 11 |
Good day, not sure if this the right place to ask question's about flow sight.
i'm using flowsight 10.0.3(j) if any one could help that would be great? i was wondering if there is there a way to show the avg on a plot or be able to export the data to excl to get the avg values. Cheer's Ian Dunlop |
April 22, 2016, 03:23 |
Reynolds
Rep Power: 10 |
Dear Ontario,
I did the same question last week. (http://www.cfd-online.com/Forums/flo...ained-air.html). I suppose that with the calculator is possible but Iīm not sure at all. Letīs wait if someone can help us... Regards. |
June 4, 2016, 16:47 |
#3 | |
Sayed-Abdol-Hamid Sajjadi
Rep Power: 10 |
the other way is opening the model in Flowsigth, after defining a prob point on model in Flowsigth and using the query option you can see a diagram with your chosen variables. its very quick and easy but there are some limitation in this. if you want more details for using it just tell me. anyway, i prefer using the Flow3D if i want to plot data and i suggest you to use it because you had to use "Excel" and it is more professional and easier to plot data. |
June 14, 2016, 16:45 |
Pankaj Lawande
Rep Power: 12 |
Hello Ian
Flowsight now has new feature called calculations in display table. To use this you will have to create query using appropriate probe and variable and then display it. At the end of display table you will find new calculations table which has most of commonly used functions like min, max, avg, fft etc. |
FlowSight - Multiple Legends of the Same Variable? | Carmen412 | FLOW-3D | 1 | June 14, 2016 16:53 |
FlowSight - Context file jumps viewport into different locations | DanMor | FLOW-3D | 2 | August 6, 2015 14:07 |
Flowsight Visualisation - Pressure Difference | Chesterton | FLOW-3D | 1 | August 13, 2014 14:30 |
