difficulty on how to implement shot sleeve simulation in flow 3d cast |
October 10, 2014, 03:28 |
ankur singh
Rep Power: 12 |
I was unable to do shot sleeve simulation( high pressure die casting) in flow3d cast ,any one plz me .
Thankyou |
October 11, 2014, 02:16 |
ankur singh
Rep Power: 12 |
Any one plz help
October 13, 2014, 16:29 |
MC
Rep Power: 17 |
Did you try the tutorials in the Help menu?
October 16, 2014, 10:59 |
ankur singh
Rep Power: 12 |
Dear melissa,
I have done tutorial , but not completely understand things , like what is metal input , can I use this in high pressure die casting simulation. when I trying to run simulation with out use metal input, simulation progress show always 0% , but, when I use metal input ,simulation progress start increasing . so plz solve my this basics problem. |
December 7, 2014, 17:34 |
Mohamed Refaat Abo El-Fotouh
Rep Power: 12 |
Same Problem here... Please any help
December 25, 2014, 02:33 |
Rep Power: 12 |
Ankur Singh did you solve the problem???
December 27, 2014, 15:58 |
Rep Power: 12 |
Dear ankur
Be careful for the signs of the velocity of the plunger.. To tell the software about the real direction you need |
January 23, 2015, 17:57 |
MC
Rep Power: 17 |
Metal input is another way to define metal into the domain other than at mesh
To create the piston you must define a moving geometry To define the fluid within the shot sleeve you will need to define a fluid region (Cast 3.5) as geometry Metal type |
January 24, 2015, 03:24 |
#9 |
Rep Power: 12 |
How much time the solver takes to calculate the problem? Please with the pc machine configurations
January 26, 2015, 13:37 |
#10 |
MC
Rep Power: 17 |
Depends on number of cells, physics activated, and the flow velocities.
You can start to run the simulation and look at time step and divide that into estimated fill time to get an idea but the time step will get smaller as the velocity gets higher. |
April 6, 2015, 11:34 |
shrinkage porosity, surface defect, hot spot, air back pressure
#11 |
ankur singh
Rep Power: 12 |
can any one help me, to find out these result, i tried to much but can't find proper result , can any one solve my problem then i send STL model to their emails
[swak4Foam] installing funkySetFields | prapanj | OpenFOAM Community Contributions | 65 | October 8, 2015 18:46 |
1.5-dev GCC-4.5.1 | linnemann | OpenFOAM | 22 | November 3, 2010 04:09 |
[swak4Foam] wmake groovyBC in OpenFOAM 1.7 ? | randomid | OpenFOAM Community Contributions | 1 | August 27, 2010 06:15 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 05:37 |
Natural convection - Inlet boundary condition | max91 | CFX | 1 | July 29, 2008 21:28 |
