Home > Forums > Software User Forums > FLOW-3D
Two inlets with different fluids
Like Tree1Likes
  • 1 Post By pedroxramos
Old   August 7, 2014, 07:26
Default Two inlets with different fluids
Pedro Ramos
pedroxramos is on a distinguished road
I am simulating the confluence of two flows of fluids with different density.
How can I define the association between each inlet and each fluid?
Best regards.
ramakant likes this.
pedroxramos is offline   Reply With Quote
Old   August 8, 2014, 19:53
Jeff Burnham
JBurnham is on a distinguished road
Activate Density Evaluation physics > 1st (or 2nd) order Approximation to Density Transport Equation. Make your mesh block so there is a boundary condition at the main inlet and a different side at the 2nd inlet. Set density on the boundary condition dialog (use velocity or pressure boundary, whichever you have data for). Alternatively, use a mass/momentum source as the inlet of the second channel -instead- of the boundary condition. Either way, specify density.
JBurnham is offline   Reply With Quote
Old   August 11, 2014, 02:33
Akshay Kumar
Akshay is on a distinguished road
Hi Jeff
Could you explain why you choose a source instead of a boundary condition for the second channel?
Akshay
Akshay is offline   Reply With Quote
Old   August 11, 2014, 13:28
Jeff Burnham
Sure. They do the same thing, essentially. Boundary conditions are maybe a little better because they have more options. That said, the mesh blocks are rectangular, and so it's not always easy to get a channel to a boundary condition.
You might put a second mesh block in to make getting the side channel to a boundary easier (with fewer cells), but then you have inter-block interpolation which can affect conservation of momentum and add uncertainty to the results. In short, if it's not "easy" to get a side channel to the mesh block boundary, then it's better to use a mass-momentum source.
Usually my only consideration when picking a mass-momentum source vs. a mesh block is minimizing the number of mesh blocks and the number of cells - to improve efficiency.
If you use a negative flow rate the mass-momentum source becomes a sink: in that case make sure it's always completely 100% submerged (like on the bed floor, facing up). If it's a source (+ rate) then it can point any direction.
Hope that helps.
Old   August 13, 2014, 02:32
Akshay Kumar
Hi Jeff
Yes that does make sense. But when we use a source, we should be more careful in the mesh and resolve the entrance region void of any small distortions at the corners/edges of the entrance region so that there is no disturbed inlet flow that comes in.
Old   February 10, 2017, 06:49
Default 3 different fluid at 3 different inlet
karthikeyan subramaniam
kkn1494 is on a distinguished road
good morning
my domain consist of 3 different inlets,.
at 1st inlet water
2nd milk
3rd which is open to atomspere
my doubt is how to set this boundry condition in fluent??
wat is the name of milk in fluent material property??
thank you
kkn1494 is offline   Reply With Quote
confluence, density, flow3d, two phases
Fluids from two Inlets opposing each other Arvind CFX 18 February 10, 2017 18:11
Input 2 inlets with different fluids keby9 FLUENT 0 December 7, 2012 09:30
Two pressure inlets problem Medison CFX 1 August 22, 2012 07:50
two inlets with two different fluids discovolante Main CFD Forum 1 April 13, 2009 09:27
Multiple Inlets Charlie V FLUENT 0 May 28, 2001 03:29
