Home > Forums > Software User Forums > FLOW-3D
reducing cfpk in mesh block
Like Tree8Likes
  • 3 Post By Saeid
  • 2 Post By Zograth
  • 3 Post By JBurnham
Old   June 27, 2014, 12:11
Default reducing cfpk in mesh block
mina salehi
mina00 is on a distinguished road
İn my mesh block simulation results writing ''in mesh block 2 recommend reducing cfpk by factor of 10''
what is cfpk????
http://upcity.ir/images2/98634055806309742224.jpg
mina00 is offline   Reply With Quote
Old   June 28, 2014, 18:26
Saeid Ahmadvand
Saeid is on a distinguished road
in program window, go to:
Model setup>>Numerics>>
"Volume of Fluid Advection" part and then>> Advanced option>>
you can change F-packing Coefficient there. (cfpk)
mina00, boy and inner7549 like this.
Saeid is offline   Reply With Quote
Old   July 2, 2014, 19:34
frode gimsøy
Zograth is on a distinguished road
All your problems are because of your mesh. With a good mesh you can avoid cfpk errors.
mina00 and boy like this.
Zograth is offline   Reply With Quote
Old   July 5, 2014, 21:40
Jeff Burnham
JBurnham is on a distinguished road
Zograth is right that a good mesh can eliminate F-packing errors, but there are other causes. In particular, whenever the free surface makes a sharp corner that oscillates in position (e.g., the toe of hydraulic jumps, the impingement trumpet of a falling jet) there will be F-packing errors there.
They are warnings, and do not mean that there is a problem with the solution. In cells that get the warning, the pressure solution is being artifically adjusted slightly to make sure that all underwater cells have fluid fraction F = 1 (keeping proper mass accounts). The rest of the cells have the usual pressure solution, so they tend to protect the cell that is being adjusted.
Usually you can ignore F-packing errors.
JBurnham is offline   Reply With Quote
Old   July 8, 2014, 12:08
mina salehi
Hello JBurnham
I refined the mesh and this error is solve. But another problem appear.
I attached my prepin file.
can you help me??
http://upir.ir/934/weir.zip
So thanks.
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[ICEM] ICE Mesh in ICEM - Block merge AA29 ANSYS Meshing & Geometry 19 March 23, 2018 07:08
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
