March 27, 2014, 10:22 |
time step in flow3D
mina salehi
Rep Power: 12 |
Hi All.
I have many questions about Flow 3D. I've just started working with the software. 1) selection of time step in Flow 3D is basedon? I don't know, how select time step? 2)what is selected finish condition based on ? finish time or fill fraction? 3) How to determine the number of mesh cells? Thanks alot for your guiding. |
March 28, 2014, 06:39 |
Maxime
Rep Power: 12 |
1) What do you mean by "basedon" ? Flow 3D calculates the best time step during simulation. But you can define min and max time step in "numerics" option (optional). 2) Depend on what you search. What do you want to simulate with Flow 3D ? If you simulate cavity filling (for exemple casting process), "Fill fraction" is good. To watch water comportment into a tube, you have to select "Finish time". 3) With the "FAVOR" method ("Mesh & Geometry" tab). You apply a cell size (or cells number), then you can watch your geometry modelisation with these mesh conditions. Reduce cell size if the geometry isn't correctly modelised. Good luck |
March 30, 2014, 05:02 |
mina salehi
Rep Power: 12 |
Dear macsim
Thanks a lot. I do not know how I would choose the time step? I want to simulate flow over a weir. Which one should I choose? Fill fraction or Finish time? Thanks. |
March 30, 2014, 08:23 |
Maxime
Rep Power: 12 |
Hello mina,
I think you can do a first simulation with an initial time step at 0.01 (numerics option). And depending results, try to minimize this initial time step. For flow over a weir you have to choose finish time. For its value, try to calculate it depending of your simulation conditions (where the fluid is starting, during how many time you want to see flow over the weir...). Have a nice Sunday. |
April 4, 2014, 14:40 |
mina salehi
Rep Power: 12 |
Thanks a million
High Courant Number @ icoFoam | Artex85 | OpenFOAM Running, Solving & CFD | 11 | February 16, 2017 14:40 |
Rapidly decreasing deltaT for interDyMFoam | chrisb2244 | OpenFOAM Running, Solving & CFD | 3 | July 1, 2014 17:40 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 10:20 |
calculation diverge after continue to run | zhajingjing | OpenFOAM | 0 | April 28, 2010 05:35 |
