Home > Forums > Software User Forums > FLOW-3D
turbulance parameter
Like Tree5Likes
  • 2 Post By JBurnham
  • 1 Post By razieh anari
  • 1 Post By JBurnham
Old   January 3, 2014, 07:49
Default turbulance parameter
razieh anari
razieh anari is on a distinguished road
Hi
1- what is the mean of pressure in flow 3d? dynamic or static?
2- what is the mean of turbulent energy? is the same kinetic energy of turbulence?
k=0.5(u'2+v'2+w'2)
u', v', w' are Average volatility.
thanks a lot .
razieh anari is offline   Reply With Quote
Old   January 3, 2014, 13:57
Jeff Burnham
JBurnham is on a distinguished road
1) p = static pressure.
2) turbulent energy = turbulent kinetic energy, TKE, just as you have guessed:
k = 0.5(u'^2+v'^2+w'^2). TKE has units of L^2/t^2 (J/kg in SI).
On the Simulation Manager tab (and in Analyze > Probe > General History Data) there is an output called "mass-averaged turbulent energy":
MTKE = sum(k*mass)/sum(mass). In FLOW-3D variables,
MTKE = sum(k*rho*f*vf*del)/sum(rho*f*vf*del).
Rho is local fluid density, f is local fluid fraction (volume fluid in cell/open volume in cell), and vf is local volume fraction (open volume in cell/total volume in cell), and del is the cell volume dx*dy*dz. The term rho*f*vf*del = mass of fluid in cell.
zhouyu3092070 and mina00 like this.
JBurnham is offline   Reply With Quote
Old   April 26, 2014, 15:30
Default turbulent dissipation
razieh anari
hello, thank you for your answers:
please tell me, what is the differences between turbulent energy and turbulent dissipation?
turbulent dissipation is reynolds stresses?if not, what's its formula?
i need u' , v' , w' , can i have these from out put result?
Milad h likes this.
Old   July 13, 2014, 07:40
mh
Milad h is on a distinguished road
hi razieh
(i need u' , v' , w' , can i have these from out put result?)
can you solve this problem?
Milad h is offline   Reply With Quote
Old   July 14, 2014, 12:00
Jeff Burnham
You can get u', v', w' from LES turbulence modeling. You can't get the velocity fluctuation components separately from RANS turbulence (like k-e or k-w).
Milad h likes this.
Old   July 14, 2014, 18:11
mh
Hi JBurnham
thank u
but, How do i get u', v', w' from output??
Old   July 18, 2014, 14:17
Jeff Burnham
Use FlowSight (the new post-processor that comes with v11). It can calculate the time-mean velocity values u_, v_, w_ in all cells over a steady-state flow. Then have FlowSight perform an arithmetic operation to subtract: u, v, w - u_, v_, w_ = u', v', w'. From the new fluctuation variables, you can find the max/min, 95th percentile, etc.
Milad h likes this.
calculating output parameter in cfd post markus67 CFX 3 August 26, 2015 10:28
Force can not converge colopolo CFX 13 October 4, 2011 23:03
Error when input new parameter in Fluent micro11sl FLUENT 0 July 1, 2011 07:42
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
Expert Parameter for compressible transient ioannis CFX 0 November 2, 2005 20:28
