Home > Forums > Software User Forums > FLOW-3D
numerical simulation tsunami
Like Tree5Likes
  • 1 Post By dmilano
  • 1 Post By dmilano
  • 1 Post By dmilano
  • 1 Post By dmilano
  • 1 Post By max0014
Old   September 27, 2012, 12:53
Default numerical simulation tsunami
hossein
hossein2357 is on a distinguished road
hi
i want to scrutiny effect tsunami on break water,but i dont know which software (ex:flow-3d,ansys-cfx,ansys-flid ...) can best chosed.
please help
all the best
hossein2357 is offline   Reply With Quote
Old   September 28, 2012, 13:53
dmilano is on a distinguished road
For what it's worth, I just saw a presentation on tsunami modelling in FLOW-3D by Osamu Kiyomiya from Waseda University,Tokyo.
hossein2357 likes this.
dmilano is offline   Reply With Quote
Old   October 19, 2012, 15:42
hossein
hi,
How i can produce tsunami wave in flow3d with piston(wave maker)
thanks a lot
Old   October 19, 2012, 15:54
You'll want to use the GMO model to simulate the motion of the sea floor.
Old   November 19, 2012, 07:22
hossein
hi,
How i can prodouce tsunami wave in flow3d
i dont know,how we must use "shallow water" for tsunami wave
Old   November 19, 2012, 11:19
The GMO approach should still work with the shallow water model. Just be sure to keep all of the geometry in the lower cell and it should be fine. Alternatively, you could try using the wave boundary condition to create the waves.
Old   November 19, 2012, 11:42
hossein
When i use "shallow water",the flow3d want to be number cell mesh in z direction 2cell. my model in z direction have 300cell!
that Seems strange to me
what should i do?
Old   November 19, 2012, 12:03
The shallow water model uses depth-averaged equations and therefore only needs two cells in z. It expects all geometry and fluid to be in the lower cell; the upper cell is used to apply the boundary conditions at the free surface. If you define your problem in this way it should work.
Old   November 19, 2012, 16:00
max
max0014 is on a distinguished road
Yes just like dmilano suggested you can make all your geometry (300 cells in z-direction) into bottom cell; use upper cell to apply boundary condition at the free surface.
max0014 is offline   Reply With Quote
Old   November 19, 2012, 17:53
hossein
How i can place geometry (300 cells in z-direction) into bottom cell?
Old   November 19, 2012, 18:14
max
just combine 300 cells into 1.
Old   December 4, 2012, 05:54
hossein
hi
when i use shallow water and run program.
The wave player normally can not be seen. ex:in 2D and X-Z plane, I see the color of the lower cell.
can we see shallow water the normal display?
Numerical simulation of Shock tube problem p07ip705 Main CFD Forum 0 May 28, 2012 03:00
Numerical Simulation of Evaporating Droplet Laxman FLUENT 0 January 14, 2011 02:38
About numerical filtering in direct simulation? leaf Main CFD Forum 0 June 20, 2006 02:57
numerical simulation of a hydrocyclone caowei Main CFD Forum 0 January 22, 2002 05:09
3-D Contaminant Dispersal Simulation Apple L S Chan Main CFD Forum 1 December 23, 1998 11:06
