Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Internal and External Analysis - SolidWorks Flow Simulation
Like Tree1Likes
  • 1 Post By Eriador
Old   October 8, 2024, 21:10
Default Internal and External Analysis - SolidWorks Flow Simulation
Eriador is on a distinguished road
I would like to perform some analyses containing both internal and external flow at the same time.
For example, in an empty and completely sealed box, I would like to simulate an external flow with a certain velocity and observe the behavior of the internal fluid.
If I define the analysis as external and set a velocity, will this velocity also be applied to the internal volume?
I ran some simulations, and apparently, the internal fluid is not affected by the external air velocity defined in the wizard, but I would like to be sure.
I know there is the possibility of using the fluid subdomain function. However, what I noticed is that when defining the internal fluid’s velocity, pressure and temperature, they remain fixed (I could be wrong). I wouldn’t want these boundary conditions to be fixed. I would like the internal fluid to move freely, for example, when I insert a heat source inside this internal fluid.
Are these boundary conditions in the fluid subdomain just the initial condition of the fluid?
Eriador is offline   Reply With Quote
Old   October 10, 2024, 12:19
Florian
native is on a distinguished road
Hi Eriador,
Yes, it's possible to have two separate fluid domains. As you've expected, the conditions in the subdomain window serve as initial conditions. If you apply a heat source and gravitational force, a natural convection will develop.
Best regards
Florian
native is offline   Reply With Quote
Old   October 10, 2024, 14:54
Hi Florian,
Thank you for your help!
native likes this.
Internal vs. External flow sim for ram air duct SCoss Main CFD Forum 0 May 11, 2023 00:21
Difference between External and Internal flow radiation problems Kummi FLUENT 0 April 10, 2018 04:06
Combining Internal and External Flow Simulation in SolidWorks rishabm Main CFD Forum 0 December 19, 2017 22:01
External flow or Internal flow boundary domain dinhanh Main CFD Forum 0 June 4, 2017 07:43
