Working on what-if scenarios with Solid Edge FLOEFD |
August 16, 2021, 11:49 |
Andre Coutinho
Hello guys,
I'm trying to work on what-if scenarios, but I wasn't able to use a dimension as a parameter for simulation. I have tried to set a dimension and use it as a variable but I've not succeed. There is some way to do it? I'm using Floefd 2021.1 and solid edge 2021. I would appreciate any help. |
October 6, 2021, 02:50 |
Disabled
Rep Power: 24 |
If your model is parametric, then you should be able to see the CAD parameters in the Parametric Study when clicking on the button "add variable" in the image below. This opens a list of parts with their parameters where you can pick the parameter you want. It helps to name the parameters to easier find them rather than not knowing which parameter is V342.
If you are still having issues, please contact your support team and they will be able to show you in a screen sharing session on how it is done. Regards, Boris |
[solids4Foam] How to calculate drag coeff when using solids4Foam | amuzeshi | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 15 | November 7, 2019 12:50 |
Importing Solid Edge files into ANSYS student | dbh0006 | ANSYS | 0 | March 22, 2019 16:05 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Defining Solid Zones Not working | elmcmaster | FLUENT | 3 | May 22, 2009 07:14 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 15:20 |
