Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
FloEFD API from Python script. Set2DTableData problem.
Like Tree4Likes
  • 1 Post By dmitry.grigoryev
  • 1 Post By Boris_M
  • 2 Post By dmitry.grigoryev
Old   March 6, 2018, 08:00
Default FloEFD API from Python script. Set2DTableData problem.
Dmitry Grigoryev
dmitry.grigoryev is on a distinguished road
A try to set up boundary conditions in FloEFD project from python script and I have a problem with setting up the data for Table dependency parameter. I call the FloEFD API function like this(for example, arrays of length 1):
 error = param.Set2DTableData([0.015], [2.0])
After I call the API getter function:
_, valueX, valueF = param.Get2DTableData()
Received output:
valueX  = (2.5e-323,)
valueF = (2.5e-323,)
I don't have any idea about this behavior. Thanks for any tip
Elaine He likes this.
dmitry.grigoryev is offline   Reply With Quote
Old   March 28, 2018, 08:51
Disabled
Boris_M will become famous soon enough
Hi Dmitry,
The API is meant for VBA, VB, and VC++.
I cannot tell if there is any compatibility with Python and wouldn't trust it delivering correct values. Have you tried it in the supported languages in a simple example to see what the feedback there is?
Regards,
Boris
Boris_M is offline   Reply With Quote
Old   May 4, 2018, 09:41
Dmitry Grigoryev
Received output:
I had solved this problem by explicit casting input data for Set2dTableData to VT_ARRAY object(FloEFD documentation says the input data type is VARIANT).
Python example:
win32com.client.VARIANT(pythoncom.VT_ARRAY | pythoncom.VT_R8, value)
Boris, thanks for your advice, it was really helpful for me.
Boris_M and Elaine He like this.
api, floefd, floefd api, python
Slicing extracted part of a volume in Python script wilmbas OpenFOAM Post-Processing 4 April 28, 2016 18:14
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 02:10
FloEFD API - SolidWorks Modeling j.gerber FloEFD, FloWorks & FloTHERM 10 December 7, 2010 22:14
[ICEM] Problem in geometry creation by script lavoz ANSYS Meshing & Geometry 4 March 12, 2010 11:56
ICEM script problem Zbynek CFX 0 October 12, 2004 08:05
