Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Results from parameter study
Like Tree1Likes
  • 1 Post By Boris_M
Old   February 23, 2015, 03:03
Default Results from parameter study
-mAx-'s Avatar
Maxime Perelli
-mAx- will become famous soon enough
I computed one parameter study with stroke of piston as parameter.
All design points are done, and I want to observe the flowfield on a plane for each stroke.
If I load one result-set, I see the result "patched" on another grid, and the stroke of piston in't updated.
So I cannot post-process my parameter study.
Is there a workaround?
I am running 13.1 Version
Thanks a lot
In memory of my friend Hervé: CFD engineer & freerider
-mAx- is offline   Reply With Quote
Old   March 2, 2015, 09:27
Disabled
Boris_M will become famous soon enough
Hi Maxime,
If you define the plots you want to post process before running the parametric study, then you can select them as output information as well as goals and the images are created directly after each calculation.
If you haven't done this you cannot directly do any changes in the parametric study but you can export the design points as separate projects and use the compare feature to compare a plot you created in one project and get the same plot for all projects you select in the compare feature.
Boris
Boris_M is offline   Reply With Quote
Old   March 3, 2015, 09:27
-mAx-'s Avatar
Maxime Perelli
Hello Boris,
Unfortunately I didn't get your last point.
I am quite lazy for computing all the design points again.
So I have one design point (project), and in this one I created my parameter study.
All my points are included in this parameter study and I am not able to call any of those points, except from "load data from", and I need then to choose one of the results included in the parameter study folder.
Old   March 3, 2015, 10:58
Disabled
You can right click on the design point name in that table and use the create project. I think you can also use multi select and do that for all of them or so. I don't have the software open at the moment.
Boris
-mAx- likes this.
Old   March 4, 2015, 05:18
-mAx-'s Avatar
Maxime Perelli
yes, I got it now.
Thank you
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 21:49
Transient Run - Output "Time" in partial results? evcelica CFX 2 May 16, 2012 22:36
Lost Scenario Results..?? Fugacity Autodesk Simulation CFD 1 February 24, 2012 11:48
Grid Refinement Study - How many cells necessary for accurate results? ejvikings FLUENT 1 January 22, 2012 01:33
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 21:11
