How to build current blower fan model in Flotherm |
January 26, 2015, 04:49 |
Eric Lin
Method 1:Build fan housing geometry and create one fan (smart part) at fan outlet fan construction:rectangular fan and dedine non-linear fan curve
Method 2:Build fan housing geometry and create two fan (smart part) at fan inlet(top&buttom) fan construction:Axial fan and dedine non-linear fan curve Method 3:Build fan housing geometry and create recirculation devices fan construction one supply and two extract Question 1:Which way is best method for blower fan? Question 2:About P-Q curve, Why the fan outlet flow rate can't meet P-Q SPEC? such as SPEC Qmax=15 CFM, but fan outlet flow rate just only 12 CFM Question 3:When I use method 2, How do I define P-Q curve value for two fan? |
January 27, 2015, 03:06 |
Gabriel Ciobanu
Rep Power: 15 |
hello,
this might be useful: http://webparts.mentor.com/flotherm/...arts/v6blower/ somehow it tells you to use "method 3" Best regards, Gabriel |
November 24, 2020, 10:20 |
Nam Shaheb
Rep Power: 6 |
Have you found the solution to your problem? I am also looking for help in this.
January 2, 2021, 03:36 |
Hank Chung
Rep Power: 10 |
Personally I prefer the method 3.
Both model 1 and 2 will calculate the pressure drop of the fan geometry, that is why the outlet flow rate is lower than P-Q curve. For model 3, you can define the P-Q same as the original one because recirculation device does not consider the geometry and pressure loss. |
blower, fan, recirculation |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Centrifugal Fan Model - Frozen Rotor | aulrich | CFX | 16 | October 16, 2014 06:13 |
[Pointwise] cannot set "fan" boundary condition to 2D Ducted fan model | brksnn | Pointwise & Gridgen | 1 | January 11, 2013 10:05 |
Native fan model? | Vcent | FLUENT | 0 | December 10, 2012 08:36 |
how to model sloping fan in Flotherm? | szcaxman | Main CFD Forum | 0 | July 10, 2004 04:35 |
