Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Extremely high fluid temperatures with simple model
Like Tree1Likes
  • 1 Post By Boris_M
Old   January 19, 2014, 20:45
Default Extremely high fluid temperatures with simple model
Jason
Jason_2 is on a distinguished road
Hi all,
I recently ran into an issue with extremely high solved steady state temperature values within the solid and fluid when a volume/surface heat source is defined (in Watts, or Watts/m^2) in FloEFD.
The model was simplified to have an external air flow (v(x) = 1 m/s) past a rectangular block (3.56 x 4.32 x 2.20 mm), where the rectangular block was a heat source of 5 W. The rectangular block was a solid made of Stainless steel 321 (Predefined) with k = 15.1 W/mK @ 300K.
The resulting temperature profile looks correct: stagnant flow on the front edge of the block, with flow trails on the other faces. The issue here is that the maximum temperature of the fluid is about 900 K. A quick calculation shows that the change in temperature should only be about 15 K, and not 600 K. Is there something I am missing in the physics, or is there something I am not addressing when creating the model?
Thank you.
More information:
Quick calculation:
Q_out (rectangle block) = Q_in (into fluid)
5 W = dm/dt * c(air) * dT
5 W = v * (cross sectional area of computational domain) * density (air) * c(air) * dT
5 W = 1 m/s * 0.015 m * 0.0175 m * density(air) * c(air) * dT
5 W = 1 m/s * 0.015 m * 0.0175 m * ~1.2 kg/m^3 * ~ 1000 J/kgK * dT
dT = 15.9 K
Mesh had an initial refinement of level 3, but partial cells were further refined by 1 level.
Gravity was turned on (a(y) = -9.81 m/s^2). Radiation was turned on, and the rectangular block was assumed to be a blackbody. The goals that were set were GG Average temperature and VG (of the rectangle block) Max Temperature.
Jason_2 is offline   Reply With Quote
Old   January 23, 2014, 05:33
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
What you are estimating is the temperature difference of the fluid if all of the fluid crossing the domain would take the same amount of heat.
It clearly does not, the fluid further away from the centerline does not take any heat.
Then still, the solid temperature would have to be higher than this estimation because there has to be a temperature gradient to transfer the heat.
Those 900K seem quite realistic to me.
To be sure you should compare the energy flux at the interface between solid and fluid to the heat source. They should be equal.
flotus1 is offline   Reply With Quote
Old   January 24, 2014, 00:12
Jason
Thank you Alex, I see where I went wrong with my physics. I checked the energy flux at the solid/fluid interface, and I got a surface generation of 3.9 W ignoring radiation and 2 W when I included radiation. The model defined the solid to have a volume heat generation of 5 W. Can I consider this as equal?
Also, what happens if the solid I am using says it is melting (because the melting point is below 900 K)? Does that mean there is heat being conducted away in the real system that I am not accounting for in such a simplified model?
Old   January 24, 2014, 04:14
flotus1's Avatar
Alex
Does it mean that the radiative heat flux has the opposite direction than the conductive heat flux? So the hot body gains heat through radiation? That would be strange.
But since the heat fluxes dont match the heat generation rate anyway, we cant consider this solution converged.
It would be best to monitor the temperature of the body along with the heat fluxes at the interfaces during the simulation.
Based on these graphs, you can see better when the solution is converged.
We should leave the rest of the discussion until we gain confidence in the simulation result.
Old   January 25, 2014, 00:35
Jason
I tightened the convergence criteria of the heat transfer rate from Auto (1 W!! Silly me) to 0.1 W. Ignoring radiation, I get the expected value of 5 W at the solid/fluid interface. Including radiation, I get a heat transfer rate of 2.6 W at the solid/fluid interface. I guess I am missing something fundamental in the radiation model? Thank you for your patience Alex
Old   January 26, 2014, 05:52
flotus1's Avatar
Alex
Help me out a bit since I dont know the program you are using.
...Ignoring radiation, I get the expected value of 5 W at the solid/fluid interface...
Do you refer to a simulation that does not account for radiation or do mean when you post-process only the conductive flux through the interface?
Same thing here. is this a different simulation than the first one you were referring to?
Additionally, we need to know which kinds of heat fluxes the software post-processes. Specifically, If we can tell apart the conductive and the radiative heat flux at the interface.
Old   January 27, 2014, 20:39
Jason
Ah, I had made two separate models where one did not account for radiation effects and the other did account for it. I am fairly certain that the software postprocessses and displays the heat transfer rate as the convective heat transfer rate, and not the radiative heat transfer rate. I cannot determine whether the software has the ability to display the radiative heat transfer rate.
Old   January 28, 2014, 04:17
flotus1's Avatar
Alex
In this case it all makes sense, although there has to be a way to postprocess the radiative heat flux aswell.
In the simulation without radiation, the convective heat flux of around 5W at the interface equals the heat generation rate. That is what we wanted.
In the simulation with radiation, the convective heat flux is only 2.6 W, so the difference between this and the heat generation rate has to be the radiative heat flux if the simulation is converged. The temperature of the solid body should be lower in this simulation.
You could check if the radiative heat flux is in the range of the analytic formula
\dot{Q} = \frac {\partial Q} {\partial t} = \varepsilon \, \sigma \, A \, \Delta T^4
Old   January 29, 2014, 20:31
Jason
The dimension of the solid is 4.32 mm x 3.56 mm x 2.2 mm and it reaches roughly 900 K at solid state. The solid was defined as a blackbody and so the radiative heat flux should be ~ 2.4 W. This agrees with what you said ! Thank you for your help Alex
Old   March 5, 2014, 08:43
Disabled
Boris_M will become famous soon enough
Hi Jason,
The surface parameter can give you clear answer in the post processing if you haven't defined a surface goal for the "heat transfer rate" (convection) and the "net radiation rate" (emitted radiation).
So you should see 2.4W radiation and 2.6W convection.
The results are plausible if you consider the size of the body and a similar body would be a light bulb with 6 W that reaches even higher temperatures but under natural convection and typically just a thin wire.
Jason_2 likes this.
Boris_M is offline   Reply With Quote
Multiphase simulation of bubble rising Niru CFX 5 November 25, 2014 14:57
ansys cfx solver exit with return code 1!!!!! mhabibnia CFX 7 August 19, 2013 04:53
Best mesh-free fluid model? muffinman123 Main CFD Forum 0 June 27, 2012 06:37
Reaching too high Temperatures using turbulentHeatFluxTemperature BC Wokl OpenFOAM Running, Solving & CFD 0 March 28, 2012 10:19
Combustion model - Fluid Material geothokar CFX 60 August 11, 2009 08:31
