Home > Forums > Software User Forums > FloEFD, FloWorks & FloTHERM
Axial fan Efficiency Goals calculation?
Like Tree3Likes
  • 1 Post By Sanghyun - PARK
  • 2 Post By Boris_M
Old   January 10, 2013, 19:16
Question Axial fan Efficiency Goals calculation?
Korean Pie
Sanghyun - PARK is on a distinguished road
Hi~
I check the efficiency of the axial flow fan.
Example Roating Impeller.
Goals -> Equation -> Pressure drop
={SG Av Static Pressure 1}-{SG Bulk Av Static Pressure 1}
Goals -> Equation -> Efficiency
={Pressure Drop}*{Environment Pressure 1:Volume flow rate normal to face:1.500e+000}/{Rotating Region 1:Angular velocity:3.665e+002}/{SG Torque (Z) 1}
Copy Top Examples of axial fans.
However, efficiency is a mess.
How to Set Goals for efficiency axial flow fans need to see?
< Unit >
pressure - Pascal
Volume Flow rate - m³/s
Torque - N.m
Efficiency - % [no unit]
Please explain the situation in more detail goals.
Anandltvs likes this.
Sanghyun - PARK is offline   Reply With Quote
Old   February 18, 2013, 12:20
Disabled
Boris_M will become famous soon enough
Hi Sanghyun,
the best way is to do it as it is done in the tutorial "Rotating Impeller" that comes with the software.
Please take care of your boundary condition, use volume or mass flow rate for the inlet and pressure for the outlet. And ideally naming the boundary conditions or goals correctly if you post here as I have no idea of where surface goals are put and surface goal static pressure 1 is not helping to identify your problem from the text. Also a boundary condition in your equation goal named "Environment pressure 1" but a flow rate beeing specified can confuse.
Also check for your angular velocity units. The whole equation goal only calculated with the values, not the units so the units should match already or you would have to include conversion factors in the equation.
In general rotating region calculations can fluctuate in the beginning for a while until they become stable. Check the inflow and outflow volume flows if the sign is correct. They can switch directions in the beginning and converge towards later iterations only.
Boris
Sanghyun - PARK and Anandltvs like this.
Boris_M is offline   Reply With Quote
axial fan, efficiency, impeller
torque calculation to find efficiency of fan bhanu1810 STAR-CCM+ 5 September 2, 2015 04:58
Fan efficiency Calculation sivakumar OpenFOAM Post-Processing 3 March 28, 2014 06:29
Simulation of Axial Fan Flow using A Momentum Source Subdomain Liam CFX 28 July 16, 2013 09:24
Axial fan or blower cooling a hot object with recirculation mariconeagles96 CFX 4 April 18, 2012 09:41
Warning 097- AB Siemens 6 November 15, 2004 05:41
